2015-07-14
09:49 PM
2023-07-13
04:20 PM
Doreena Deng
Code:
// Addon.cpp
// --- Addon ------------------------------------------------------------
#include "Palette.h"
GSErrCode __ACENV_CALL Initialize (void)
GSErrCode err = NoError;
// Prevent the add-on auto-unloading
ACAPI_KeepInMemory(1);
// Install menu handler
err = ACAPI_Install_MenuHandler (32500, APIMenuCommandProc_32500);
return err;
} /* Initialize */
GSErrCode __ACENV_CALL FreeData (void)
Palette::DeleteInstance();
return NoError;
} /* FreeData */
GSErrCode __ACENV_CALL APIMenuCommandProc_32500 (const API_MenuParams *menuParams)
DBPrintf ("Test::APIMenuCommandProc_32500() %d/%d\n", menuParams->menuItemRef.menuResID, menuParams->menuItemRef.itemIndex);
Palette::ToggleVisibility();
return NoError;
// Palette.h
#pragma once;
// --- Palette ------------------------------------------------------------
class Palette: public DG::Palette
friend class PaletteObserver;
private:
static Palette* m_pPalette;
static PaletteObserver* m_pPaletteObserver;
enum {
CloseButtonId = 1
DG::Button closeButton;
private:
Palette(short resId);
public:
~Palette();
void SelectionChanged(const API_Neig *selElemNeig);
static Palette& GetInstance();
static bool HasInstance();
static void DeleteInstance();
static void ToggleVisibility();
// --- PaletteObserver ------------------------------------------------------------
class PaletteObserver: private DG::PanelObserver,
public DG::ButtonItemObserver,
public DG::CompoundItemObserver
private:
Palette* m_palette;
public:
PaletteObserver (Palette* palette);
~PaletteObserver();
virtual void SourceDestroyed (GS::EventSource* evSource);
virtual void PanelOpened (const DG::PanelOpenEvent& ev);
virtual void PanelCloseRequested (const DG::PanelCloseRequestEvent& ev, bool* accepted);
virtual void PanelClosed (const DG::PanelCloseEvent& ev);
virtual void PanelResized (const DG::PanelResizeEvent& ev);
virtual void ButtonClicked (const DG::ButtonClickEvent& ev);
// Palette.cpp
#if !defined (ACExtension)
#define ACExtension
#endif
#if defined (_MSC_VER)
#if !defined (WINDOWS)
#define WINDOWS
#endif
#endif
#if defined (WINDOWS)
#include "Win32Interface.hpp"
#pragma warning (disable: 4068)
#endif
// ------------------------------ Includes -------------------------------------
#include <stdio.h>
#include <math.h>
#include <string.h>
#if defined (macintosh)
#include <MacTypes.h>
#endif
#include "DG.h"
#include "DGModule.hpp"
#include "ACAPinc.h"
#include "APICommon.h" // also includes GSRoot.hpp
static GS::Guid PaletteGuid ("{9597C98D-95BD-48d9-9999-C2297834806B}");
static GSErrCode __ACENV_CALL ModelessWindowCallBack (long referenceID, API_PaletteMessageID messageID)
if (Palette::HasInstance() && referenceID == Palette::GetInstance().GetId()) {
switch (messageID) {
case APIPalMsg_ClosePalette:
Palette::GetInstance().SendCloseRequest();
break;
case APIPalMsg_HidePalette_Begin:
break;
case APIPalMsg_HidePalette_End:
break;
case APIPalMsg_DisableItems_Begin:
break;
case APIPalMsg_DisableItems_End:
break;
return NoError;
/*static*/ Palette* Palette::m_pPalette = NULL;
/*static*/ PaletteObserver* Palette::m_pPaletteObserver = NULL;
/*static*/ Palette& Palette::GetInstance()
if (!m_pPalette) {
GSResModule actResModule = ACAPI_UseOwnResModule ();
m_pPalette = new Palette(32420);
ACAPI_ResetResModule (actResModule);
m_pPaletteObserver = new PaletteObserver(m_pPalette);
return *m_pPalette;
/*static*/ bool Palette::HasInstance()
return m_pPalette != NULL;
/*static*/ void Palette::DeleteInstance()
DBASSERT(m_pPalette != NULL);
if (m_pPalette != NULL) {
delete m_pPalette;
m_pPalette = NULL;
if (m_pPaletteObserver != NULL) {
delete m_pPaletteObserver;
/*static*/ void Palette::ToggleVisibility() {
if (m_pPalette != NULL && m_pPalette->IsVisible()) {
m_pPalette->EndEventProcessing();
m_pPalette->Hide();
} else {
Palette::GetInstance().BeginEventProcessing();
m_pPalette->Show();
Palette::Palette(short resId) : DG::Palette(resId, PaletteGuid),
closeButton (GetReference (), CloseButtonId)
ACAPI_RegisterModelessWindow (GetId(), ModelessWindowCallBack,
API_PalEnabled_FloorPlan +
API_PalEnabled_Section +
API_PalEnabled_Detail +
API_PalEnabled_Layout +
API_PalEnabled_3D
Palette::~Palette ()
ACAPI_UnregisterModelessWindow (GetId());
void Palette::SelectionChanged(const API_Neig *selElemNeig)
if (selElemNeig->neigID != APINeig_None)
DBPrintf("Last selected element: NeigID %d; guid: %s, inIndex: %d\n",
selElemNeig->neigID, (const char *) APIGuid2GSGuid (selElemNeig->guid).ToUniString ().ToCStr (),
selElemNeig->inIndex);
closeButton.Enable();
} else {
DBPrintf("All elements deselected\n");
closeButton.Disable();
PaletteObserver::PaletteObserver (Palette* palette)
: m_palette (palette)
if (DBVERIFY (m_palette != NULL)) {
palette->Attach (*this);
AttachToAllItems (*m_palette);
PaletteObserver::~PaletteObserver ()
if (m_palette != NULL) {
m_palette->Detach (*this);
DetachFromAllItems (*m_palette);
// ... Public methods ..........................................................
void PaletteObserver::SourceDestroyed (GS::EventSource* evSource)
if (evSource == m_palette) {
//MarkAsFinished ();
//notesObserver->FindPaletteDestroyed ();
//palette = NULL;
// ... Dialog notifications ....................................................
void PaletteObserver::PanelOpened (const DG::PanelOpenEvent& /*ev*/)
SetMenuItemMark(32500, 1, true);
/*palette->findEdit.SetText (palette->findData->findText);
palette->replaceEdit.SetText (palette->findData->replaceText);
FindValidate ();
if (palette->findData->findWholeWord)
palette->wholeWordCheck.Check ();
if (palette->findData->findMatchCase)
palette->matchCaseCheck.Check ();
if (palette->findData->findWrap)
palette->wrapCheck.Check ();
if (palette->findData->findUp)
palette->upRadio.Select ();
else
palette->downRadio.Select ();
palette->findEdit.SetFocus ();*/
void PaletteObserver::PanelCloseRequested (const DG::PanelCloseRequestEvent& /*ev*/, bool* /*accepted*/)
m_palette->EndEventProcessing ();
void PaletteObserver::PanelClosed (const DG::PanelCloseEvent& /*ev*/)
SetMenuItemMark(32500, 1, false);
void PaletteObserver::PanelResized (const DG::PanelResizeEvent& ev)
short dh = ev.GetHorizontalChange ();
short dv = ev.GetVerticalChange ();
m_palette->BeginMoveResizeItems();
//dialog->separator.Move (dh, 0);
m_palette->closeButton.Move (dh, dv);
m_palette->EndMoveResizeItems();
// ... Dialog item notifications ...............................................
void PaletteObserver::ButtonClicked (const DG::ButtonClickEvent& ev)
if (ev.GetSource () == &m_palette->closeButton) {
m_palette->SendCloseRequest ();
2015-07-20 12:45 PM
Resource chain is gone (also ACAPI_UseOwnResModule() and ACAPI_ResetResModule() along with it)So you should remove all of your ACAPI_UseOwnResModule() and ACAPI_ResetResModule() calls and then that problem will be solved
OS X internally maintained a stack of open resource files called the resource chain. Whenever you want to load a resource, the system searched downwards in this stack to find the resource in any of the open resource files below the current one.
We removed that implicit mechanism; you'll have to specify each and every time the resource module explicitly (usually with ACAPI_GetOwnResModule()).
Palette::Palette(short resId) : DG::Palette(resId, PaletteGuid),to this:
Palette::Palette(short resId) : DG::Palette(ACAPI_GetOwnResModule(), resId, ACAPI_GetOwnResModule(), PaletteGuid),(You can find DG::Palette::Palette constructor in DGDialog.hpp header file.)
2015-07-20 03:35 PM
2015-07-21 04:13 PM
/* Text appearing in the menu */
'STR#' 32500 "Menu strings" {
/* [ ] */ "Test"
/* [ ] */ "DG Functions"
/* [ 1] */ "Open Example Palette"
'STR#' 32520 "Prompt strings" {
/* [ ] */ "Test"
/* ---------------------------------------------------------- Example Palette */
'GDLG' 32590 Palette | hGrow | close 0 0 160 40 "Test Palette" {
/* [ 1] */ Button 10 10 140 20 LargePlain "Hide"
'DLGH' 32590 DLG_32580_Test_Palette {
1 "" Button_0
ExamplePalette.hpp
// ---------------------------------- Includes ---------------------------------
#include "APIEnvir.h"
#include "DG.h"
#include "DisposableObject.hpp"
#define EXAMPLEPALETTE_RESID 32590
// --- ExamplePalette ----------------------------------------------------------
class ExamplePalette: public DG::Palette,
public DG::PanelObserver,
public DG::CompoundItemObserver,
public GS::DisposableObject
private:
enum {
HideButtonId = 1
DG::Button hideButton;
ExamplePalette (GSResModule dialResModule, short resId);
protected:
virtual void PanelOpened (const DG::PanelOpenEvent& ev) override;
virtual void PanelResized (const DG::PanelResizeEvent& ev) override;
virtual void PanelCloseRequested (const DG::PanelCloseRequestEvent& ev, bool* accept) override;
virtual void ButtonClicked (const DG::ButtonClickEvent& ev) override;
public:
static const GS::Guid paletteGuid;
static Int32 paletteRefId;
ExamplePalette ();
~ExamplePalette ();
static GSErrCode __ACENV_CALL PaletteAPIControlCallBack (Int32 referenceID, API_PaletteMessageID messageID, GS::IntPtr param);
// --- ExamplePaletteManager ---------------------------------------------------
class ExamplePaletteManager : public GS::DisposeHandler
private:
ExamplePalette* examplePalette;
ExamplePaletteManager ();
ExamplePaletteManager (const ExamplePaletteManager& source); //disabled
ExamplePaletteManager operator= (const ExamplePaletteManager& source); //disabled
public:
~ExamplePaletteManager ();
static ExamplePaletteManager& GetInstance ();
static void OpenExamplePalette ();
static void CloseExamplePalette ();
static bool IsExamplePaletteOpened ();
ExamplePalette* GetExamplePalette ();
virtual void DisposeRequested (GS::DisposableObject& source) override;
}; // ---------------------------------- Includes ---------------------------------
#include "ExamplePalette.hpp"
//------------------------------ Class ExamplePalette --------------------------
const GS::Guid ExamplePalette::paletteGuid ("{D8A0A01F-1184-40F2-B8A8-28CF30714FA4}");
Int32 ExamplePalette::paletteRefId = (Int32) GS::GenerateHashValue (ExamplePalette::paletteGuid);
ExamplePalette::ExamplePalette ():
DG::Palette (ACAPI_GetOwnResModule (), EXAMPLEPALETTE_RESID, ACAPI_GetOwnResModule (), paletteGuid),
hideButton (GetReference (), HideButtonId)
Attach (*this);
AttachToAllItems (*this);
SetDefaultGarbageCollector ();
SetDisposeHandler (ExamplePaletteManager::GetInstance ());
ExamplePalette::~ExamplePalette ()
Detach (*this);
DetachFromAllItems (*this);
void ExamplePalette::PanelOpened (const DG::PanelOpenEvent& /*ev*/)
void ExamplePalette::PanelResized (const DG::PanelResizeEvent& ev)
short vGrow = ev.GetVerticalChange ();
short hGrow = ev.GetHorizontalChange ();
if (vGrow != 0 || hGrow != 0) {
BeginMoveResizeItems ();
hideButton.Move (hGrow, vGrow);
EndMoveResizeItems ();
void ExamplePalette::PanelCloseRequested (const DG::PanelCloseRequestEvent& ev, bool* /*accept*/)
if (ev.GetSource () != this)
return;
Hide ();
MarkAsDisposable ();
void ExamplePalette::ButtonClicked (const DG::ButtonClickEvent& ev)
if (ev.GetSource () == &hideButton) {
Hide ();
GSErrCode __ACENV_CALL ExamplePalette::PaletteAPIControlCallBack (Int32 referenceID, API_PaletteMessageID messageID, GS::IntPtr param)
if (referenceID == paletteRefId) {
case APIPalMsg_OpenPalette:
ExamplePaletteManager::OpenExamplePalette ();
break;
ExamplePaletteManager::CloseExamplePalette ();
break;
if (ExamplePaletteManager::IsExamplePaletteOpened ())
ExamplePaletteManager::GetInstance ().GetExamplePalette ()->Hide ();
break;
ExamplePaletteManager::GetInstance ().GetExamplePalette ()->Show ();
break;
ExamplePaletteManager::GetInstance ().GetExamplePalette ()->DisableItems ();
break;
ExamplePaletteManager::GetInstance ().GetExamplePalette ()->EnableItems ();
break;
case APIPalMsg_IsPaletteVisible:
*(reinterpret_cast<bool*> (param)) = (ExamplePaletteManager::IsExamplePaletteOpened () && ExamplePaletteManager::GetInstance ().GetExamplePalette ()->IsVisible ());
break;
default:
break;
return err;
//-------------------------- Class ExamplePaletteManager -----------------------
ExamplePaletteManager& ExamplePaletteManager::GetInstance ()
static ExamplePaletteManager instance;
return instance;
ExamplePaletteManager::ExamplePaletteManager () :
examplePalette (NULL)
ExamplePaletteManager::~ExamplePaletteManager ()
if (DBERROR (examplePalette != NULL)) {
examplePalette->EndEventProcessing ();
delete examplePalette;
examplePalette = NULL;
void ExamplePaletteManager::OpenExamplePalette ()
ExamplePaletteManager& manager = GetInstance ();
if (manager.examplePalette == NULL) {
manager.examplePalette = new ExamplePalette ();
if (DBERROR (manager.examplePalette == NULL))
return;
manager.examplePalette->BeginEventProcessing ();
manager.examplePalette->Show ();
void ExamplePaletteManager::CloseExamplePalette ()
return;
manager.examplePalette->Hide ();
manager.examplePalette->EndEventProcessing ();
delete manager.examplePalette;
manager.examplePalette = NULL;
bool ExamplePaletteManager::IsExamplePaletteOpened (void)
return GetInstance ().examplePalette != NULL;
void ExamplePaletteManager::DisposeRequested (GS::DisposableObject& source)
if (&source == manager.examplePalette) {
ExamplePalette* ExamplePaletteManager::GetExamplePalette ()
return this->examplePalette;
Main.cpp
// Function to open the Example Palette
static void Open_ExamplePalette (void)
if (!ExamplePaletteManager::IsExamplePaletteOpened ())
return;
// Handles menu commands
GSErrCode __ACENV_CALL MenuCommandHandler (const API_MenuParams *menuParams)
switch (menuParams->menuItemRef.menuResID) {
case 32500:
switch (menuParams->menuItemRef.itemIndex) {
case 1: Open_ExamplePalette (); break;
break;
return NoError;
} // MenuCommandHandler
// Interface definitions
GSErrCode __ACENV_CALL RegisterInterface (void)
GSErrCode err;
err = ACAPI_Register_Menu (32500, 32520, MenuCode_UserDef, MenuFlag_Default);
if (err != NoError)
DBPrintf ("DG_Test:: RegisterInterface() ACAPI_Register_Menu failed\n");
return err;
} // RegisterInterface
// Called when the Add-On has been loaded into memory
// to perform an operation
GSErrCode err = ACAPI_Install_MenuHandler (32500, MenuCommandHandler);
if (err != NoError)
DBPrintf ("DG_Test:: Initialize() ACAPI_Install_MenuHandler failed\n");
err = ACAPI_RegisterModelessWindow (ExamplePalette::paletteRefId, ExamplePalette::PaletteAPIControlCallBack,
API_PalEnabled_FloorPlan + API_PalEnabled_3D + API_PalEnabled_Layout,
GSGuid2APIGuid (ExamplePalette::paletteGuid));
if (err != NoError)
DBPrintf ("DG_Test:: Initialize() ACAPI_RegisterModelessWindow failed\n");
return err;
} // Initialize
// FreeData
// called when the Add-On is going to be unloaded
ACAPI_UnregisterModelessWindow (ExamplePalette::paletteRefId);
return NoError;
} // FreeData
2015-07-22 02:15 PM
2021-11-16 02:56 PM - edited 2021-11-22 04:24 PM
nice
