Archicad C++ API
Why it's not work (About placing library object on floorplan
static void Do_MyFunction(void)
	API_Element element;
	API_ElementMemo memo;
	BNZeroMemory(&element, sizeof(API_Element));
	BNZeroMemory(&memo, sizeof(API_ElementMemo));
	double A = 0;
	double B = 0;
	Int32 parCount = 0;
	element.header.typeID = API_ObjectID;
	ACAPI_Element_GetDefaults(&element, NULL);
	ACAPI_LibPart_GetParams(20, &A, &B, &parCount, &memo.params);
	element.object.pos.x = 1;
	element.object.pos.y = 1;
	element.object.xRatio = A;
	element.object.yRatio = B;
	element.object.libInd = 20;
	GSErrCode	err = ACAPI_Element_Create(&element, &memo);
	if( err == NoError)
		ACAPI_WriteReport("Ok ",true);
	else
		ACAPI_WriteReport("Error ",true);
	ACAPI_DisposeElemMemoHdls (&memo);
It's all return Error only
P.S. I want to test on library index 20.
I'm coding this on VS2005 and ArchiCAD 14 Demo Version
7 REPLIES 7
Are you using ACAPI_OpenUndoableSession before calling this function? You should also check the error code returned by ACAPI_Element_GetDefaults and ACAPI_LibPart_GetParams.
As an aside, the library part index is temporary, i.e. you can cannot be certain what part it will refer to. I would never hard code an index like that.
Ralph Wessel BArch
Central Innovation
Thanks for your reply
OK I will check it soon.
but a little, I confuse this sentence
"library part index is temporary"
Can you explain me in detail?
	API_LibPart part;
	GSErrCode err;
	BNZeroMemory(&part, sizeof(API_LibPart));
	part.index = 20;
	err = ACAPI_LibPart_Search(&part, false);
	err = ACAPI_LibPart_Get(&part);
	double A = 0;
	double B = 0;
	Int32 parCount = 0;
	err = ACAPI_Element_GetDefaults(&element, NULL);
	err = ACAPI_LibPart_GetParams(part.index, &A, &B, &parCount, &memo.params);
	element.object.libInd = part.index;
	if( err == NoError)
	else
I use above code and it's error too
I error only on
err return
APIERR_REFUSEDCMD -2130312312 81060388 The passed identifier is not subject to the operation.
switch (menuParams->menuItemRef.itemIndex) {
case 1: Do_MyFunction (); break;
case 2: Do_CreateWindowFromHatch (); break;
I call it from this.
I don't know it's contain undoable session or not?
ACAPI_OpenUndoableSession("Test Lib");
	ACAPI_CloseUndoableSession();
OK thx.
I just place 2 undo line here.
It's work!!!
I just understand that it "must" use with undo too.
If you ask for an object with an index of '20', ArchiCAD will return whatever object has that index. But if you change the loaded libraries and ask for the object at index '20', don't be surprised if you get a different object.
Objects do not have a permanent index - refer to the object guid instead, or perhaps the name.
Ralph Wessel BArch
Central Innovation
OK I get it.
Thank you.
