nishida_jp
how can I select elements in a 3D within the range of z coordinates
In ArchiCAD 27,
how can I select elements in a 3D drawing of a building that fall within the range of z coordinates h1 to h2?
Also, how can I select elements that are part of the range?
1 Solution
Hiromichi Shinkawa
Hi, I'd suggest you to try ACAPI_Element_CalcBounds() command to have the 3D bounding box of element, then check whether it falls into your range or not.
HTH.
Go to post
2 Replies 2
Hiromichi Shinkawa
HTH.
nishida_jp
Thank you.
