Archicad C++ API
signal=11 crash on opening cocoa webview
Hello again
I'm trying to open an cocoa webview into my Archicad add-on and after it opens its possible to browse a web page for a little, and after e few random clicks on links the whole Archicad crashes just like it hits some memory limit or something.. I get this errors in the console.app:
Jun 27 11:56:25 Julians-iMac Archicad 20.app[20357]: ====>GeneralSignalHandler received signal=11
Jun 27 11:56:25 Julians-iMac Archicad 20.app[20357]: ====>GeneralSignalHandler calling OOP handler
Jun 27 11:56:26 Julians-iMac Archicad 20.app[20357]: Archicad [20357] crashed with signal 11. Report written to: /Users/ivan/Library/Application Support/Graphisoft/BugReporting-20/Archicad-20170627(08-49-05)-[20357]-FATAL.rpt
Jun 27 11:56:27 Julians-iMac Archicad 20.app[20357]: ====>GeneralSignalHandler restoring previous handlers
Jun 27 11:56:27 Julians-iMac com.apple.xpc.launchd[1]
(com.Graphisoft.Archicad.17352[20357]): Service exited due to signal: Segmentation fault: 11 sent by exc handler[0]
Basically all what I'm doing is creating an instance of nswindow and adding a webview into, all done programatically (all seems to work fine without crash on a simple c++ project, but crashes after a while with Archicad API included):
void openWindowAndWebView(void)
    NSWindow *window =
    [[NSWindow alloc]
     initWithContentRect:NSMakeRect(0, 0, 800, 600) styleMask: NSWindowStyleMaskClosable backing: NSBackingStoreBuffered defer: YES];
    [window center];
    window.title = @"Hello World";
    [window makeKeyAndOrderFront:window];
    [window setStyleMask:[window styleMask] | NSWindowStyleMaskTitled | NSWindowStyleMaskResizable];
//    Window_delegate *d = [Window_delegate new];
//    window.delegate = d;
    WebView *wb = [[WebView alloc] initWithFrame:window.contentView.frame];
    wb.autoresizingMask = NSViewWidthSizable | NSViewHeightSizable;
    [window.contentView addSubview:wb];
    [[wb mainFrame]
     loadRequest:[NSURLRequest
     requestWithURL:[NSURL URLWithString:@"http://www.cars.bg"]]];
#endif
void openWebView(void){
    WriteReport("Open web view");
#ifdef __OBJC__
    WriteReport("it is OBJC!");
    @autoreleasepool {
        openWindowAndWebView();
#endif
I will be very helpful if you can help me, or just guide me how to debug it.
Regards,
Julian
Ralph Wessel
Mentor
jcimentarov wrote:
I'm trying to open an cocoa webview into my archicad add-on and after it opens its possible to browse a web page for a little, and after e few random clicks on links the whole archicad crashes just like it hits some memory limit or something.
Some more information about the context you're opening the webview into would be useful, e.g. are running this in a separate process to ARCHICAD?
If you're running this in the same thread as the add-on, I'm not surprised it's crashing – I'd only be surprised it worked at all. I think it would play havoc with ARCHICAD's event-handling, memory and window management.
Ralph Wessel BArch
Active Thread Ltd
GSErrCode __ACENV_CALL MenuCommandHandler (const API_MenuParams *menuParams)
    if (menuParams->menuItemRef.menuResID == 32500) {
        GSErrCode errorCode = ACAPI_CallUndoableCommand ("Importer",
         [&] () -> GSErrCode {
             switch (menuParams->menuItemRef.itemIndex) {
                case  1: openFileDialog(); break;
                case  2: openWebView();break;
                default: return NoError;
        return errorCode;
    return NoError;
This is where I'm calling my method which is opening the window with the webview. I'm still a newbie to c++ and I'm not pretty sure if it runs in a different thread than the add-on. How can I check that, and if it doesn't run in a separate threat how could I fix it?
Akos Somorjai
        return errorCode;
    return NoError;
The menu command handler runs on the main thread.
My guess that here the add-on is unloaded very soon after you call the menu command, so try to call ACAPI_KeepInMemory (true); at the beginning of the MenuCommandHandler.
Best, Akos
