Archicad Python API
About automating tasks in Archicad using the Python API.
Compile Python Scripts to Executables
wkrt-hs
Dear Community,
I'm trying to compile my Python scripts to executables using pyinstaller.
Unfortunately, the executables seem to fail to connect to Archicad.
from archicad import ACConnection
conn = ACConnection.connect()
assert conn
Traceback (most recent call last):
  File "xxx", line 9, in <module>
    assert conn
AssertionError
[15984] Failed to execute script 'xxx' due to unhandled exception!
 There's already a similar topic but it is locked: Compile Python Scripts to Executables - Graphisoft Community
Did anyone already succeed with this? Building executables should be a common usecase for automation purposes.
Best, Wenzel
7 REPLIES 7
GAG
Dear Wenzel, you could try my script `archiconnect.py` which doesn't use the official Graphisoft archicad package, but could be used for connection testing.
How to test
Download latest archiconnect release from GitHub
Extract release and run `archiconnect.py` directly in Terminal or via Python:
./archiconnect.py
python archiconnect.py GetAllClassificationSystems
When running Archicad in background, you'll get output in Terminal:
Connecting to 127.0.0.1:19723 …
Is alive: True
Host version: Archicad 27 3001 INT
Creating and running PyInstaller package
Build package:
pyinstaller -F archiconnect.py
Run packed executable:
./dist/archiconnect
If this executable does or does not work in your environment, please post a short report here so we can investigate further.
George
wkrt-hs
Hi George and thank you for your reply!
Building and running your script works fine.
But it would still be nice to also use the official archicad package for this usecase.
Well, this means that you have no specific PyInstaller issues when using generic requests.
If you could provide your script, I could check/rewrite it for compatibility with PyInstaller.
George
It's literally the 3 lines from the first post that already fail.
Are you able to build and run them successfully in your environment?
I already have a working solution for the simple connect (see my first comment).
No, unfortunately, the official GS Python module doesn't work well in PyInstaller environment and I don't have enough motivation to debug and fix their code. They suppress error messages, it's not a very good practice:
    @staticmethod
    def find_first_port() -> int:
        for port in ACConnection._port_range():
            try:
                ACConnection(port)
                return port
            except Exception:
                continue
        return None
    @staticmethod
    def find_ports(ports: slice) -> List[int]:
        result = []
            try:
                ACConnection(port)
                result.append(port)
            except Exception:
                continue
        return result
I can't help you if you don't want to share your code, sorry.
George
wkrt-hs
Thanks for your response, George.
I'll see if I investigate further, but it's good to know that it's probably nothing related to my python environment.
Sure )
Maybe GS will fix their initialisation code to be compatible with the PyInstaller environment, but I haven't found an official GitHub repo for the `archicad` Python module to create an Issue.
George
