Objects to position according to coordinate list
Actually I have a list of coordinates (in a text/csv/excel file), and I have to position object elements (800 pcs) to the coordinates in the list.
I thought that a python script could do this. I tried with the excel export/import script.
But as far as I can see: with this method I can adjust almost every property, but of the object coordinates.
I need help to solve this issue.
I'm not addicted to the python method, any other solution would be welcomed.
13 Replies 13
kuvbur
If I understood you correctly,
SomeStuff add-on can write property values directly into an element's ID field using its Sync_to{ID} command.
I've updated the example file to demonstrate this specific functionality. You can download the latest version to see how Sync_to{ID} works in practice
Industrial Architect and Structural Design Engineer, developer of free addon for sync GDL param and properties
Works perfectly.
Thanks!!
Can I find the possible other parameters/fields to sync, somewhere?
Dear Berndt & runxel & Mathias,
Thanks for the info about tapir - it will help a lot later. A long time ago I wanted to try it out - but I thought it is much more complicated; now I know it's not. Your quick & concise answers really helped me.
kuvbur
Yes, of course. Automatically translated help for commands is here
