BIMcloud system components (temp)
Istvan Moharos
BIMcloud Manager
Services and Processes
WindowsmacOS
Main service
  • Service name: PortalServerService-v<Version>(Manager-<Date>)
  • Service display name: GRAPHISOFT BIMcloud Manager <Version> (Manager-<Date>)
  • Processes:
    • LicenseManager.exe
    • node.exe
    • TeamworkPortalServerManager.exe
Tray icon
  • Service name: TeamworkServiceProcessManagerAgent-v<Version>(Manager-<Date>)
  • Service display name: GRAPHISOFT Service Process Manager Agent <Version> (Manager-<Date>)
  • Processes:
    • BIMcloudMonitor.exe
    • TeamworkServiceProcessManagerAgent.exe
<Date>: The date the installation took place in YYYY-MM-DD format. <Version>: Main version number of the BIMcloud Manager (e.g.: 22.0).
Main service
  • LaunchDaemon: com.graphisoft.PortalServerService-v<Version>(Manager-<Date>).plist
  • Processes:
    • LicenseManager
    • node
Tray icon
  • LaunchDaemon: com.graphisoft.TeamworkServiceProcessManagerAgent-v<Version>(Manager-<Date>).plist
  • Processes:
    • BIMcloudMonitor
Folder locations
WindowsmacOS
Folder Path
Installation * C:Program FilesGRAPHISOFTBIMcloudManager-<Date>
Configuration .Config
Manager database ** .Data
Logs .Logs
<Date>: The date the installation took place in YYYY-MM-DD format. *: The path can be modified during the installation phase. **: The path can be modified either at the configuration phase after the installation or later by reconfiguring the BIMcloud Manager.
Folder Path
Installation * System drive/Applications/GRAPHISOFT/BIMcloud/Manager-<Date>/
Configuration ./Config/
Manager database ** ./Data/
Logs ./Logs/
BIMcloud Server
WindowsmacOS
Main service
  • Service name: TeamworkApplicationServerMonitor-v<Version>(Server-<Date>)
  • Service display name: GRAPHISOFT BIMcloud Server <Version> (Server-<Date>)
  • Processes:
    • mongod.exe
    • TeamworkApplicationServer.exe
    • TeamworkApplicationServerMonitor.exe
Tray icon
  • Service name: TeamworkServiceProcessManagerAgent-v<Version>(Server-<Date>)
  • Service display name: GRAPHISOFT Service Process Manager Agent <Version> (Server-<Date>)
  • Processes:
<Date>: The date the installation took place in YYYY-MM-DD format. <Version>: Main version number of the BIMcloud Server (e.g.: 22.0).
Main service
  • LaunchDaemon: com.graphisoft.TeamworkApplicationServerMonitor-v<Version>(Server-<Date>).plist
  • Processes:
    • mongod
Tray icon
  • LaunchDaemon: com.graphisoft.TeamworkServiceProcessManagerAgent-v<Version>(Server-<Date>).plist
  • Processes:
    • BIMcloudMonitor
Folder Locations
WindowsmacOS
Folder Path
Installation * C:Program FilesGRAPHISOFTBIMcloudServer-<Date>
Projects database ** .Projects
Libraries database ** .Attachments
BlobCache database ** .BlobCache
User sessions .Sessions
Messaging database .Mailboxes
Logs .Logs
<Date>: The date the installation took place in YYYY-MM-DD format. *: The path can be modified during the installation phase. **: The path can be modified either at the configuration phase after the installation or later by reconfiguring the BIMcloud Server.
Folder Path
Installation * System drive/Applications/GRAPHISOFT/BIMcloud/Server-<Date>/
Projects database ** ./Projects/
Libraries database ** ./Attachments/
BlobCache database ** ./BlobCache/
User sessions ./Sessions/
Messaging database ./Mailboxes/
Logs ./Logs/
BIMcloud Delta Cache
Note that BIMcloud Delta Cache is not available in BIMcloud Basic.
WindowsmacOS
Main service
  • Service name: BlobCacheService-v<Version>(Delta-Cache-<Date>)
  • Service display name: GRAPHISOFT BIMcloud Delta Cache <Version> (Delta-Cache-<Date>)
  • Processes:
    • mongod.exe
    • TeamworkBlobCacheServer.exe
Tray icon
  • Service name: TeamworkServiceProcessManagerAgent-v<Version>(Delta-Cache-<Date>)
  • Service display name: GRAPHISOFT Service Process Manager Agent <Version> (Delta-Cache-<Date>)
  • Processes:
<Date>: The date the installation took place in YYYY-MM-DD format. <Version>: Main version number of the BIMcloud Delta Cache (e.g.: 22.0).
Main service
  • LaunchDaemon: com.graphisoft.BlobCacheService-v<Version>(Delta-Cache-<Date>).plist
  • Processes:
    • mongod
Tray icon
  • LaunchDaemon: com.graphisoft.TeamworkServiceProcessManagerAgent-v<Version>(Delta-Cache-<Date>).plist
  • Processes:
    • BIMcloudMonitor
Folder Locations
WindowsmacOS
Folder Path
Installation * C:Program FilesGRAPHISOFTBIMcloudDelta-Cache-<Date>
BlobCache database ** C:ProgramDataGraphisoftBlobCacheServerCacheFolder
Logs C:Program FilesGRAPHISOFTBIMcloudDelta-Cache-<Date>Logs C:ProgramDataGraphisoftBlobCacheServerLogFolder
<Date>: The date the installation took place in YYYY-MM-DD format. *: The path can be modified during the installation phase. **: The path can be modified either at the configuration phase after the installation or later by reconfiguring the BIMcloud Delta Cache.
Folder Path
Installation * System drive/Applications/GRAPHISOFT/BIMcloud/Delta-Cache-<Date>/
BlobCache database ** System drive/Library/Preferences/Graphisoft/BlobCacheServer/CacheFolder/
Logs System drive/Applications/GRAPHISOFT/BIMcloud/Delta-Cache-<Date>/Logs/ System drive/Library/Preferences/Graphisoft/BlobCacheServer/LogFolder/
Related versions: v18 and newer
 In case of the following system components, both the network communication and file related operations need to be on the exclusion list if any antivirus/firewall/network monitoring application is used.
Components
BIMcloud Manager
Version Service / LaunchDaemon Processes
v21 Graphisoft BIMcloud Manager 21.0 (PortalServerService-v21.0) TeamworkPortalServerManager.exe Node.exe LicenseManager.exe
v20 Graphisoft BIMcloud Manager 20.0 (PortalServerService-v20.0)
v19 Graphisoft BIMcloud Manager 19.0 (PortalServerService-v19.0)
v18 Graphisoft BIMcloud Manager 18.0 (PortalServerService-v18.0)
Folders and files
Folder / File Operating System Path
Installation folder * Windows C:\Program Files\GRAPHISOFT\BIMcloud\BIMcloud Manager\
macOS System drive/Applications/GRAPHISOFT/BIMcloud/BIMcloud Manager/
Configuration folder Windows ...\BIMcloud Manager\Config\
macOS .../BIMcloud Manager/Config/
Manager's database folder ** Windows ...\BIMcloud Manager\Data\
macOS .../BIMcloud Manager/Data/
Logs folder Windows ...\BIMcloud Manager\Logs\
macOS .../BIMcloud Manager/Logs/
BIMcloud Server
v21 Graphisoft BIMcloud Server 21.0 (TeamworkApplicationServerMonitor-v21.0) TeamworkApplicationServerMonitor.exe TeamworkApplicationServer.exe Mongod.exe
v20 Graphisoft BIMcloud Server 20.0 (TeamworkApplicationServerMonitor-v20.0)
v19 Graphisoft BIMcloud Server 19.0 (TeamworkApplicationServerMonitor-v19.0)
v18 Graphisoft BIMcloud Server 18.0 (TeamworkApplicationServerMonitor-v18.0)
Folders and files
Installation folder * Windows C:\Program Files\GRAPHISOFT\BIMcloud\BIMcloud Server <version>\
macOS System drive/Applications/GRAPHISOFT/BIMcloud/BIMcloud Server <version>/
Configuration folder Windows ...\BIMcloud Server <version>\Config\
macOS .../BIMcloud Server <version>/Config/
Projects folder ** Windows ...\BIMcloud Server <version>\Projects\
macOS .../BIMcloud Server <version>/Projects/
Attachments folder ** Windows ...\BIMcloud Server <version>\Attachments\
macOS .../BIMcloud Server <version>/Attachments/
BlobCache database folder ** Windows ...\BIMcloud Server <version>\BlobCache\
macOS .../BIMcloud Server <version>/BlobCache/
Session database folder Windows ...\BIMcloud Server <version>\Sessions\
macOS .../BIMcloud Server <version>/Sessions/
Messaging database folder Windows ...\BIMcloud Server <version>\Mailboxes\
macOS .../BIMcloud Server <version>/Mailboxes/
Logs folder Windows ...\BIMcloud Server <version>\Logs\
macOS .../BIMcloud Server <version>/Logs/
BIMcloud Delta Cache (BIMcloud Proxy)
v21 Graphisoft BIMcloud Delta Cache 21.0 (BlobCacheService) TeamworkBlobCacheServer.exe Mongod.exe
v20 Graphisoft BIMcloud Delta Cache 20.0 (BlobCacheService)
v19 Graphisoft BIMcloud Delta Cache 19.0 (BlobCacheService)
v18 Graphisoft BIMcloud Proxy 18.0 (BlobCacheService)
Folders and files
Installation folder * Windows C:\Program Files\GRAPHISOFT\BIMcloud\BIMcloud Proxy\
macOS System drive/Applications/GRAPHISOFT/BIMcloud/BIMcloud Proxy/
Configuration folder Windows ...\BIMcloud Proxy\Config\
macOS .../BIMcloud Proxy/Config/
BlobCache database folder ** Windows C:\ProgramData\Graphisoft\BlobCacheServer\CacheFolder\
macOS System drive/Library/Preferences/Graphisoft/BlobCacheServer/CacheFolder/
Logs folder Windows C:\Program Files\GRAPHISOFT\BIMcloud\BIMcloud Proxy\Logs\ C:\ProgramData\Graphisoft\BlobCacheServer\LogFolder\
macOS System drive/Applications/GRAPHISOFT/BIMcloud/BIMcloud Proxy/Logs/ System drive/Library/Preferences/Graphisoft/BlobCacheServer/LogFolder/
BIMcloud Monitor
v21 Graphisoft Service Process Manager Agent 21.0 (TeamworkServiceProcessManagerAgent-v21.0) TeamworkServiceProcessManagerAgent.exe BIMcloudMonitor.exe
v20 Graphisoft Service Process Manager Agent 20.0 (TeamworkServiceProcessManagerAgent-v20.0)
v19 Graphisoft Service Process Manager Agent 19.0 (TeamworkServiceProcessManagerAgent-v19.0)
Folders and files
From version 19 all BIMcloud components contain the BIMcloud Monitor application.
BIMcloud Monitor Application Windows ...\BIMcloud Manager\BIMcloudMonitor.exe ...\BIMcloud Server <version>\BIMcloudMonitor.exe ...\BIMcloud Proxy\BIMcloudMonitor.exe
macOS .../BIMcloud Manager/BIMcloudMonitor.app .../BIMcloud Server <version>/BIMcloudMonitor.app .../BIMcloud Proxy/BIMcloudMonitor.app
Notes: * The path can be modified during the installation phase. ** The path can be modified either at the configuration phase or later by reconfiguring the affected BIMcloud component.
Communication
Communication between the client and the server side components
Source Destination Port Number Protocol
ARCHICAD 21 BIMcloud Team Client 21 BIMcloud Manager 21000 HTTP
BIMcloud Server 21 21001
BIMcloud Delta Cache 9921
ARCHICAD 20 BIMcloud Team Client 20 BIMcloud Manager 20000 HTTP
BIMcloud Server 20 20001
ARCHICAD 19 BIMcloud Team Client 19 BIMcloud Manager 19000 HTTP
BIMcloud Server 19 19001
ARCHICAD 18 BIMcloud Team Client 18 BIMcloud Manager 1228 HTTP
BIMcloud Server 18 18008
BIMcloud Proxy 9921
Communication between the server side components
If the server side components are installed on the same computer, the communication is local.
BIM Server Manager BIMcloud Delta Cache (BIMcloud Proxy) BIMcloud Server 21 21001 HTTP
 Note that the above ports are defaults, if the ports are customized, then the appropriate customized ports have to be used.
