2024-07-24
03:17 PM
2024-09-09
12:01 PM
Hi!
3D view is not available after exporting to BIMX. I only see 2D plans.
I know there should be some option to click for 3D view, but I can´t find it.
Can someone please attach a printscreen of this option, please?
I use Archicad 26.
Thank you!!
Operating system used: Windows 11 Pro 23H2
Solved! Go to Solution.
2024-09-04
03:45 PM
2024-09-09
11:59 AM
Hi ananas,
please make sure, that you did not only export a selection in the BIMx publisher set. You need to export the whole content of the publisher set.
If you only export a selection the BIMx Hyper Index will still show all of the names of the added views of your original publisher set. However, since you did not export all the 2D und 3D views, there will be missing views in your BIMx model.
Addition:
Exporting a selection can be used to update an already existing BIMx model.
Kind regards
2024-07-25 03:51 AM
Did you include a 3D view in the publisher set for your hyper-model?
2024-07-25 04:44 PM
Hi, yes I did, but it gets placed on the layout, not being viewable as 3D
2024-07-26 03:02 AM
Your Publisher set properties are set like this? ...
2024-07-29 10:23 AM
Hi!
yes, I think is correctPublisher settings
BIMx Export
in BIMX 3d Viewer I see 3D places on layout though, not as an actual 3D view.
BIMX viewer
2024-09-03
06:27 PM
2024-09-09
11:58 AM
I'm having a similar issue. Difference is my BimX model doesn't even populate the 3D views, Screen shot of the publisher set list attached. Going to try and delete the current bimx set and re built the publisher set, then reload to the model transfer site.
2024-09-04
03:45 PM
2024-09-09
11:59 AM
Hi ananas,
Addition:
Kind regards
