Read more
BIMx
About BIMx (mobile, web and desktop), connection to BIMcloud, and related technical questions.
Publishing layout failed because ArchiCAD was not able to generate it
svpribyl
I'm getting this message when I try to publish two layouts that have been updated. They have previously been published. I deleted them from the publisher set and added them again, but I still get the same message. I tried publishing them one at a time, and they fail. I restarted the computer but it doesn't help.
Any suggestions would be appreciated.
Steve Pribyl
MAC OS Sonoma 14.5
ArchiCAD 27
11 REPLIES 11
Hello Steve Pribyl,
I invite you to check :
- your layout
- your library
- your linked drawings
- your publication file location
- if your publication file is not already open
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
mikas
Go find and delete the published files in Finder, and then try to publish them again.
AC25, Rhino6/7+Grasshopper, TwinMotionMac Pro 6,1 E5-1650v2-3,5GHz/128GB/eGPU:6800XT/11.6.5 • HP Z4/Xeon W-2195/256GB/RX6800XT/W10ProWS
if the PDF created previously is open, this may cause the next publishing task to fail.'
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-5030 USA
Rhino 8 Mac
MacOS 14.5
svpribyl
To clarify, this is being published via "Upload bimx hyper-model"
I deleted the bimx model from the cloud/server and re-published it, but the same two layouts were not published.
Steve Pribyl
MAC OS Sonoma 14.5
ArchiCAD 27
svpribyl
For another test, I deleted the bimx file and just tried publishing the 2 layouts and they still fail. However, I tried publishing the two layouts to pdf files (save files) and they publish fine.
Steve Pribyl
MAC OS Sonoma 14.5
ArchiCAD 27
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Steve,
Thank you for posting this into the forums and making it available to anyone who is interested in this topic!
This error message is not very common, actually. The few cases that we had this error is when there are some special characters in the ID of the layout. My first suggestion is to rename the layout to an easy one (like test), and try to publish it to BIMx to see if there is any issue. If not, we can be sure that the layout ID needs to be renamed.
But after this test, if the layouts still fail to publish to BIMx, we will need to get the problematic file for further investigation. If you are willing to share the file with us, please reply either here within the post directly or through a PM and I will provide you a secure GRAPHISOFT link where you can upload your file to.
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Hello Minh,
I am getting the same error message.
View Name: "failed because Archicad was unable to generate it"
Saving BIMx Info: "failed because Archicad was unable to generate it" AND "missing schedules - BIMx info"
BIMx Package: "failed because Archicad was unable to generate it"
Best,
Camille She
Windows 10 Pro
Archicad 25 Solo
Hi Minh--
I'm having the same issues and followed the trouble shooting laid out above. Can you share a link with me to upload the file to so we can figure out what the problem is?
karsonardo
I'm facing an issue while attempting to publish layouts that have been recently updated. These layouts were previously published without any problems, but after making necessary edits, An error during the publishing process. I have already tried removing the layouts from the publisher set, adding them again, publishing them individually, and even restarting my computer.
