2025-06-11 04:10 AM
hii
I’m testing BIMx for presentations for the first time and I think it’s super cool! However, I noticed that the layouts (floor plans, renderings, and elevations) are showing up in poor quality and with off colors in the BIMx model.
I’m on a Mac, so I used the print settings workaround to save the layouts as a PDF, and there the quality and colors were flawless. But when I save it as bimx hyper model, they appear slightly blurred and darker colors.
Since one of the main goals is to use BIMx for presentations, I’m a bit confused about the poor layout quality.
Is there a way to export or save the layouts in higher quality into the BIMx Hyper-model?
Solved! Go to Solution.
2025-06-11 02:24 PM
Hi @cocoloco,
Thank you for your feedback!
Please report the issue using the Mail icon on the BIMx Home Screen, and our BIMx support team will check it. In your report, please attach some screenshots of the issue as well as a link to the BIMx model and its source PLA (support can also provide a link to upload your files).
Kind regards,
Oleksandra
Oleksandra Vakariuk
Technical Support Engineer2025-06-11 02:24 PM
Hi @cocoloco,
Kind regards,
Oleksandra
Oleksandra Vakariuk
Technical Support Engineer2025-06-13 12:23 AM
Hi Oleksandra, nobody responded to me ... 😕
2025-06-16 04:19 PM
Hello! I see that my colleague has responded in the meantime. Thank you for your patience, and apologies for the delay.
Oleksandra Vakariuk
Technical Support Engineer2025-08-17 10:43 PM
hello, is there any chance that BIMx will start to use vector files instead of those pixelized exports to PDF?
honestly whole thing becomes unusable as a one-click-solution to transfer files
2025-08-18 02:03 PM
The issue still persist in archicad 29
2025-09-07 04:42 PM
Hello maybe someone can reply? PDF's are still raster, not vector!
