2025-06-11 04:10 AM
hii
I’m testing BIMx for presentations for the first time and I think it’s super cool! However, I noticed that the layouts (floor plans, renderings, and elevations) are showing up in poor quality and with off colors in the BIMx model.
I’m on a Mac, so I used the print settings workaround to save the layouts as a PDF, and there the quality and colors were flawless. But when I save it as bimx hyper model, they appear slightly blurred and darker colors.
Since one of the main goals is to use BIMx for presentations, I’m a bit confused about the poor layout quality.
Is there a way to export or save the layouts in higher quality into the BIMx Hyper-model?
Solved! Go to Solution.
2025-06-11 02:24 PM
Hi @cocoloco,
Thank you for your feedback!
Please report the issue using the Mail icon on the BIMx Home Screen, and our BIMx support team will check it. In your report, please attach some screenshots of the issue as well as a link to the BIMx model and its source PLA (support can also provide a link to upload your files).
Kind regards,
Oleksandra
Oleksandra Vakariuk
Technical Support Engineer2025-06-11 02:24 PM
Hi @cocoloco,
Kind regards,
Oleksandra
Oleksandra Vakariuk
Technical Support Engineer2025-06-13 12:23 AM
Hi Oleksandra, nobody responded to me ... 😕
2025-06-16 04:19 PM
Hello! I see that my colleague has responded in the meantime. Thank you for your patience, and apologies for the delay.
Oleksandra Vakariuk
Technical Support Engineer2025-08-17 10:43 PM
hello, is there any chance that BIMx will start to use vector files instead of those pixelized exports to PDF?
honestly whole thing becomes unusable as a one-click-solution to transfer files
2025-08-18 02:03 PM
The issue still persist in archicad 29
2025-09-07 04:42 PM
Hello maybe someone can reply? PDF's are still raster, not vector!
2025-10-11 04:16 PM
maybe we deserve any reply about this raster pdf thing?!
2025-10-12 06:07 PM
Unfortunately I have never heard back about resolving this issue, apparently is in the list to check on it but its been months and no progress.
To further explain: I have no other way to save quality pdf on MacBook in archicad other than through Print to accomplish a good quality (nice colors and not blurred elevations, yeah...). I can't do it through standard way like many of these folks through publish set. Reason is, the quality is extremely poor for elevations, and especially renderings (darker colors etc) so I have to go through file > print instead.
Now, when I save project for BIMX (Publish BIMx Hypermodel) ... the quality and look of the renderings/elevations etc is EXACTLY poor and it has exact look as I would save it through Publish set. (instead the nice quality if I would go through file/print). Which makes me think that the BIMX is opening the file through the standard archicad way and does not account for MacBook users who have to go through unreasonable way of workaround to save file in high quality...
2025-10-16 01:41 PM
Thank you all for your input!
@cocoloco, the issue about darker colors has been fixed in Archicad 29 version 3000. Please confirm colors appear properly in BIMx Hyper-models exported from the latest Archicad.
@cocoloco @brzmidobrze, regarding the resolution of the layouts in Hyper-models, there have been related wishes in the past, however it's not yet entered to our public wishlist. Please feel free post it there, describing the problem and your solution ideas!
Note that one of the biggest benefits of BIMx is opening even very complex and large layouts fast on any, even low-end mobile device. This is why layouts are rasterized during BIMx export with 250dpi, well-balanced for digital use on mobile devices. Larger resolution would increase export and loading time, file size, and memory usage significantly. Another option would be the vectorial export indeed, which would be great. Let's continue this on the wishlist.
Best regards,
Dani Benjamin
