2 questions with interactive schedules
Achille Pavlidis
Hi, a couple of questions on interactive schedules:
1) Is it possible to add a footer with a custom text? Not date/project name/etc that are allready set?
2) Is it possible to have the Sunshade appear in the "3D Front View"?
Thanks
Mac OSX 13.6.6 | AC 27 INT 5003 FULL
19 REPLIES 19
Achille Pavlidis
Nobody???
OK, I have another question:
Is it possible to have the Zone Schedule list the objects that are placed inside a zone?
Achille Pavlidis
Another one:
Is it possible to sort the data according to a scpecific column, or do I have to export to excel and then re-import?
Achille wrote:
Another one:
Yes - these buttons are what you are after.
Achille wrote:
Nobody???
Looks like you can get the number of objects but not the names.
Achille Pavlidis
Thanks Barry!
What about my first two questions?
Thanks
1) Not that I am aware of - you are stuck with what they allow.
2) I'll take a guess on this one.
If it is a separate object then no it won't show in a window schedule.
But you would be able to create a new schedule that would look for this object.
If it is part of a window it should show unless it has been scripted in a way not to.
You would need to edit the script to get it to show.
Achille Pavlidis
1) OK...
2) It is actually part of the window library part... I can get the field to display the "Sunshade Type", but the preview image doesn't actually show it...
thanks anyway.
Achille wrote:
1) OK...
thanks anyway.
I'd be guessing that in the 3D script of the window there will be a bit of code like ...
if GLOB_CONTEXT <> 6 then
script for sunshade
endif
If there is you can comment out the red bits.
But I might be wrong.
Is it a standard library part that we all have?
Achille Pavlidis
Yes totally standard W2 Tilt-Turn 14
Learn and get certified!
