2006-07-12 10:57 PM
2006-07-20 10:30 PM
2006-07-20 11:03 PM
2006-07-21 04:16 PM
2006-07-21 09:42 PM
2006-07-22 01:02 AM
2006-07-22 03:18 PM
sfriday wrote:sfriday:
Maybe I can do it with shading too which is what I like.
Thanks Again.
Dwight wrote:Dwight:
I'm no expert in the layout book but what if a layout sheet had a published perspective view on it. Overlaid on top, you could annotate and dimension in 3D and also update the 3D.
2006-07-22 03:45 PM
2006-07-22 03:48 PM
2006-07-23 02:42 AM
This will work with the Internal Engine Analytic Shading mode. In ArchiCAD 9, the shading color will be changed to the closest pen color. In ArchiCAD 10, a matching uneditable RGB color will be assigned to the fill.
I then ran into the problem of losing my dimensions if I moved or streched the image box that holds the axon view. If I explode the image box it turns all the colors to grayscale. SO I ended up exploding the dim. strings once I plugged in the correct measurements.
3rd dimension tool - objexonlyne
