Collaborate forum
3D Window Explore Spazzes Out
Gerry Leonor
our current Work From Home Setup for the office is using a work VPN & logging onto our office workstations via Window Remote Desktop Connection.
the one thing I found, on day one, is that when i go to the 3D window, start Exploring, & the moment I look
around with the mouse, the view spazzes out.
"Spazzes out" is a scientific term. i was about to describe something that involves John Lennon & whatever he had while writing Lucy in the Sky with Diamonds & Walter White, sitting next to him, with a fresh pack...but i'll spare people with my futile attempt at humour.
link below is a video that shows the experience.
https://1drv.ms/u/s!AgnwiRVSv3c_la43vh-nm5yUYpcZEw?e=DhdP9z
the last 7 or 8 seconds is me trying to move the mouse 1mm per 2 seconds to try & calm the camera down 42,000 notches...
i hope the link works. i think you may have to download it -- no preview, unfortunately.
AC25 | Win10 | 64 bit | 16Gb RAM |Intel i7 8700 @ 3.20Ghz
come join our unofficial Discord server
https://discord.gg/XGHjyvutt8
Legend
Video played fine in my browser.
WRDP does not support OpenGL... which AC kind of needs... I did have occasional success launching AC via TeamViewer before swapping back to WRDP. Not sure if it is related, but I had the same thing happen in both AC and Lumion. Had to change the method I was remote accessing...
Ling.
AC22-23 AUS 7000
Self-taught, bend it till it breaks.
Win10 | R5 2600 | 16GB | GTX1660
Creating a Thread
Help Those Help You - Add a Signature
15 REPLIES 15
Legend
Ling.
AC22-23 AUS 7000
Creating a Thread
Gerry Leonor
figures...
i was hoping it wasn't something to do with an email from our IT people regarding OpenGL issues & Remote Desktopping...
thank you.
Legend
Apparently, it is also only an issue for non-Quadro cards...
AC22-23 AUS 7000
Creating a Thread
Erwin Edel
I've had similar issues with Nvidia Quadro QPU and RDP.
We are trying to run AC local and share our network license with VPN, but it's still a work in progress on the IT side of things.
www.leloup.nl
ArchiCAD 9-24 NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Jp1138
I´ve seen a similar behaviour with Chrome Remote Desktop and Teamviewer using Archicad and also Twinmotion. I think it´s related to the way mouse input gets to the origin computer. In Archicad the problem only arrises with the Explore view, but at least I can orbit perfectly on a normal 3dview. In twinmotion it´s also very dificult to move using the subjective view. Right now I don´t think it has anything to do with Opengl, at least with Chrome or Teamviewer.
ARCHICAD 26 SPA
Windows 10
Legend
TeamViewer worked fine for me. My issue with TeamViewer was how it handles continuous key presses... ie. no magic wand...
AC22-23 AUS 7000
Creating a Thread
Jp1138
Yes, I think that was the one real problem we had with Teamviewer. Works ok in Chrome remote desktop, though.
ARCHICAD 26 SPA
Windows 10
By the sounds of it there isn't a solution to this "spazzing out" where employing VPN to office PC?
Legend
It is less the VPN, more the program used to read information over that VPN. The main issue here is that Windows Remote Desktop Protocol does not support OpenGL.
Ling.
AC22-23 AUS 7000
Creating a Thread
alexandregrignon
We also encountered problems in 3D with the same type of connection (VPN + Remote Desktop).
We fixed it by updating the NVIDIA graphics drivers.
Gerry Leonor
i'm wondering if anyone who uses the 3D mouse made by 3DConnexion has any spazzing issues with the 3D window. i can't do my usual 3D flythrough exploration of my model when i'm working from home because of the constant spazzing out of the window when i activate the 3D Flythrough, but with the 3D mouse, the Flythrough isn't even activated & you can still explore the model.
https://www.amazon.com.au/3Dconnexion-SpaceMouse-Compact-3D-Mouse/dp/B079V4PXYD/ref=sr_1_5?dchild=1&...
also, i did you guys a favour by already searching for "3D mouse" on Amazon & finding the link to the exact product. you're welcome.
Erwin Edel
3D exploration does not work at all with remote desktop.
It's not related to your 3DConnexion device. I get the same problems with a 'normal' mouse.
The problem has to do with the way OpenGL is supported (or lack thereof) through remote desktop.
The workaround from AC23 onwards (I think?) is to press J for Joystick. Which will but a circular dot on your screen to control the turning of the camera.
www.leloup.nl
Windows 10 Pro
Erwin Edel
I will add that using the joystick mode is a poor substitute for the productivity I have with exploration on a non remote desktop setup in the office.
www.leloup.nl
Windows 10 Pro
Legend
Try out Parsec. I have had none of the issues I have had with WRDP or Teamviewer. Video compression is also much better with Parsec vs Teamviewer.
Ling.
AC22-23 AUS 7000
Creating a Thread
Gerry Leonor
thank you -- i understand that the 3D Explorer doesn't work because it's OpenGL that messes up.
but my follow-up question was regarding the use of the 3D mouse peripheral & whether a user, working from home & remote-desktopping into their workstation, is able to use it to explore the 3D window as smoothly as 3D explorer without having to activate the function & just by simply using the peripheral.
TL;DR
is there anyone with a 3DConnexxion 3D mouse that's used it at home while remote-desktopping into their PC at work? how has their experience been?
