3DS Import
stefan
I used to be able to import OBJ-files into ArchiCAD with surface smoothing intact.
http://www2.asro.kuleuven.ac.be/asro/English/HOME/SBs/tutorial/tips/viz2ac.htm
(Explained with 3DStudio VIZr3, but this will work in Maya as well, since Alias|Wavefront was the inventor of the OBJ-format).
AFAIK, ArchiCAD 8.x doesn't read OBJ-files anymore
Another solution, slightly worse, but better then DXF for that matter is importing it as a 3ds-file (Maya should be able to do that, you might need to download some translator-plugins, though).
This 3ds-import was once mailed to me by some German ArchiCAD user and I can send the full plugin to you if you want (it was free, so I don't think I break any copyrights here).
Archicad27/Revit2023/Rhino8/Unity/Solibri/Zoom
MBP2023:14"M2MAX/Sonoma+Win11
Archicad-user since 1998
my Archicad Book
39 REPLIES 39
Thanx for the link but for some reason archicad doesn't like the plugin, quote "The file is an outdated Add-on that cannot be used with this Archicad virsion" possibly this plugin was for 7 and not compatible with 8?
stefan
I also have a version for ArchiCAD 7
(The 8-version might be for 8.0 and thus not compatible with 8.1?)
my Archicad Book
Djordje
Ace
Yep, that is the case. Regretfully.
This import API should be standard!!!!!
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
How could one import 3ds in Archicad
for 7
what do you mean "for 7" ?
for AC7
please help me out!
I am a new learner for ArchiCAD.
I downlard the folder that you attach, but I still don't know how to use. :oops: Do I just import into the library manager? then I can use .3ds object?
