2004-01-19 08:45 AM
2004-03-24 02:43 AM
2004-03-24 10:07 AM
2004-05-12 11:35 PM
2004-05-13 09:54 AM
Bricklyne wrote:I don't have 7.0 and don't use 8.0 anymore, so I can't help you. The plugins are not compatible when the API (the plugin programming part) changes between versions.
Stefan,
None of those plugins work at all with either AC v7 or 8. It says that they are outdated ot not meant for that specific version of ArchiCAD. Perhaps you might ask your german friend about a bug free copy.
2004-05-13 11:12 AM
2004-05-13 11:16 AM
2004-05-13 11:28 AM
Bricklyne wrote:Hmmm ... could it be the version? US vs Int vs Ger vs Can vs Whatever?
What I had meant to convey to you was the fact that the plugins do not work when used with ArchiCAD version 8.0 (for the v8 one) nor with version 7.0 (for the v7 one) . I have all three versions of ArchiCAD installed in my computer (from v7-8.1). I never tried to use them with v8.1 because I already knew that they wouldn't work!!
2004-05-13 11:31 AM
keithg wrote:This was after he downloaded the v8 llugin with his v8 ArchiCAD and before you posted the v7 plugin as well. So it was not a version compatibility problem with him either. FYI I got the same message in both versions of ArchiCAD, 7 and 8 with their respective plugin versions. I believe there is yet another person in the forum who also reported the same, although I can't seem to find their post or recal their name at the moment. So it's not just me!
Thanx for the link but for some reason archicad doesn't like the plugin, quote "The file is an outdated Add-on that cannot be used with this Archicad virsion" possibly this plugin was for 7 and not compatible with 8?
2004-05-13 11:35 AM
Djordje wrote:Bricklyne wrote:Hmmm ... could it be the version? US vs Int vs Ger vs Can vs Whatever?
Don't shoot the messenger
2004-05-13 01:42 PM
Bricklyne wrote:I don't like the tone this discussion is getting...Djordje wrote:Now that's a real possibility!! Something we (or at least I) never thought about. Good thinking Djorde!!!
Perhaps you might also want to let Stefan in on that last line.
