Collaborate forum
3d polyline terrain data from DWG to Archicad
Hello,
I have to get 3-d polyline terrain data into an archicad22-project (cant attach a dwg here... ). I dont want to use the points-to-.txt-method if possible, because of the amount of data. Also redrawing is too much work.
It should be possible to export the data as an IFC Site, but i dont know how to define the polygons as IFC-Site in autocad Map 3d 2018. I also got access to revit, but no experience.
Help would be much appreciated!
2 REPLIES 2
Afraid the only way we got anywhere a few years ago was indeed getting the coordinates into an .xyz text file to import.
www.leloup.nl
ArchiCAD 9-24 NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Lingwisyer
Champion
If you have ArchiTerra, you can convert your dwg into a dxf and ArchiTerra can build a mesh for you from that. Pretty sure it reads 3d polylines.
Ling.
AC22-23 AUS 7000
Self-taught, bend it till it breaks.
Win10 | E5620 x 2 | 24GB | K2200 RIP PSU
Win10 | R5 2600 | 16GB | GTX1660
