2008-08-28 03:56 PM
2008-08-28 08:57 PM
2008-09-08 07:31 AM
2020-01-21 09:56 AM
2020-02-04 02:30 PM
GOBA wrote:Hi,
Hello, this is a very old post. I am not sure if I should write here, or I should write a new one, but I am also having trouble with DWG leaders an ArchiCAD labels.
I have this label in ArchiCAD:
I can export it into leader in DWG, or into text and lines, using this:
If it’s exported as a leader, there is a new style generated in DWG, but the underline is missing, so I should modify it:
Is there anything I am doing wrong? Furthermore, there is a font-style conversion in the DWG translator, but I have not seen any conversion for labels and dimensioning. Is there any?
In the other way around, I have a similar problem. If I place a external drawing in ArchiCAD, the DWG leader doesn’t have the underline:
Is this normal?
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-02-05 11:41 PM
2020-02-11 05:28 AM
Minh Nguyen
GRAPHISOFT
2020-02-11 06:51 AM
mnguyen wrote:Hi Minh!
Therefore, in order to avoid this, the workaround is to turn it off. Although the labels will not be converted to leaders in AutoCAD, it will keep the same look of the label in the result DWG!
mnguyen wrote:You can download a sample here:
And thank you very much for your suggestion on the second issue about text box, but unfortunately, I haven't been able to replicate it. Is it possible for you to send me a sample DWG file so that I can see which setting is causing this issue? Thank you very much!
2020-02-27 08:25 AM
2020-02-27 08:44 AM
Minh Nguyen
GRAPHISOFT
2020-02-27 08:59 AM
2020-02-27 09:04 AM
Minh Nguyen
GRAPHISOFT
2020-03-01 02:28 PM
Minh Nguyen
GRAPHISOFT
2020-03-01 11:36 PM
2020-03-02 07:55 AM
Minh Nguyen
GRAPHISOFT
2020-03-02 08:50 AM
2020-03-13 04:13 PM
2020-03-16 02:50 AM
Dyana wrote:Hi Dyana,
On the subject of leaders in AC23- In Autocad you can create a leader and add text or not, BUT you can add multiple leaders onto one!
Is there a way to make leader (In archicad "text Label") with out text AND how do you add multiple leader heads?
Minh Nguyen
GRAPHISOFT
2020-03-18 12:09 PM
