Collaborate forum
AC10 converter
naomihansen
I have some old files I need to convert. I found the AC10 Converter, and downloaded it, but it won't run. All the discussions here are from 2017 or older, so I'm assuming this is a problem with newer operating systems and 32-bit compatibility. Does anybody know how I could do this? The files are .pln from 2006.
Thanks!
Naomi
Naomi Hansen
Terry & Terry Architecture
Running AC24 on Mac OSX10.15.6
4 REPLIES 4
If you have an SSA contract with Graphisoft, you can send the files to them for conversion.
Think Like a Spec Writer
AC24-6004 / USA AC25-4013 USA
Rhino 7 Mac
MacOS 11.6.1
naomihansen
Interesting... I'll look into that.
Thanks!
Naomi
Naomi Hansen
If you don't have an SSA contract, you would have to run the converter on a pretty old Mac (needs QuickTime and other 32 bit stuff). In my case I installed it in a 64 bit Windows 10 virtual machine (on my Mac) and it runs fine there should I need it. If you have access to any kind of Windows computer, that might be an easy option.
One of the forum moderators   •   AC 25 USA and earlier   •   MacOS 11.6.3, iMac Pro
naomihansen
OK, good to know. I'm not even sure what kind of contract we have with Graphisoft, so am looking into that. If not, the PC conversion sounds like a good way to go.
Thanks!
Naomi
Naomi Hansen
