2021-04-28 06:41 AM
Sending-Error The Server cannot confirm, if the last sending operation was finished. In any case your last changes are safe. To make sure, the changes remain safed, we recommend you to NOT continue working on the project and instead try first to sucessfully send the changes. If you continue to make changes on the project, it is likely you cannot send any changes to the server anymore.
Solved! Go to Solution.
2021-05-03 04:42 AM
Noémi Balogh
Customer Engagement Expert, Community Admin
2021-05-04 08:54 AM
2021-05-03 04:42 AM
Noémi Balogh
2021-05-04 08:54 AM
2021-05-11 02:50 AM
