AC26 Folder BUG: Info Box Implementation
Eduardo Rolon
Though the search field is welcome it has display problems in the Info Box:
  1. You cannot see all options as in previous versions unless you scroll or guess at a name.
    1. AC26
    2. Prior to 26
  2. When using folders you can only see what is inside that current folder
  3. Column width is fixed. This means that you have to wait until the "overview" shows. GS says they are in the process of fixing it but at this point is a BUG.
    1.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Mjules
Mentor
Will Graphisoft really fix it? How long do we have to wait for a solution?
In normal conditions, each new version should have provided fixes for previous issues. In the case of Graphisoft, it seems that each new Archicad version brings its own set of problems.
Martin Luther Jules
AC 10-27 (Full)
Asus | 64 GB RAM | Windows 11
Eduardo Rolon
Another place where a multi-column layout was removed is the Materials palette, though they exchanged the "click" to display for scroll.
Also this is one of the places that I think the new Folders might work.
Prior to 26
AC26
AC27 US/INT -> AC08
another Moderator
