2023-02-13 10:50 AM
Up until AC25, you could export a single pen table as a .txt file. That .txt file would have all the pen info for that particular table (number, RGB values, weight, description). I would import this into an Excel workbook to quickly reformat for better comprehension.
It seems this is no longer an option with AC26. Is this deliberate?
Solved! Go to Solution.
2023-02-13 02:33 PM
Bruce:
Try opening the old Attribute Manager, select a Pen Set in the upper panel, select all the Pens in the lower panel (can use Command+A), click the Save as TXT button at the bottom.
2023-02-13 09:38 PM
Thanks David. How do I open the old attribute manager in AC26?
2023-02-13 10:03 PM
Options menu > Attribute Manager
It was brought back with the first update to 26.
2023-02-13 10:12 PM
Thanks Karl. That wasn't in my Options menu...the dangers of applying a legacy work environment!
2023-02-14 02:18 AM
You bet. It also shows as an icon in the standard Attributes Toolbar (one of the ones I usually keep on and docked). The old and new are right next to each other there.
