Project data & BIM
AC26 Pen Table Export as .txt File
Bruce
Up until AC25, you could export a single pen table as a .txt file.  That .txt file would have all the pen info for that particular table (number, RGB values, weight, description).  I would import this into an Excel workbook to quickly reformat for better comprehension.
It seems this is no longer an option with AC26.  Is this deliberate?
Bruce Walker
www.brucepwalker.com
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC26 5002 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
Bruce
Thanks David.  How do I open the old attribute manager in AC26?
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
5 REPLIES 5
David Maudlin
Bruce:
Try opening the old Attribute Manager, select a Pen Set in the upper panel, select all the Pens in the lower panel (can use Command+A), click the Save as TXT button at the bottom.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Bruce
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Options menu > Attribute Manager
It was brought back with the first update to 26.
One of the forum moderators
Bruce
Thanks Karl.  That wasn't in my Options menu...the dangers of applying a legacy work environment!
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
You bet.  It also shows as an icon in the standard Attributes Toolbar (one of the ones I usually keep on and docked).  The old and new are right next to each other there.
