2003-11-20 06:19 PM
2003-12-02 05:46 AM
2003-12-02 07:00 AM
Shaz wrote:8.1 will have solved it.
Has anyone experienced AC8.3 crashing when importing an AutoCAD drawing, while AC7.3 opens it just fine???
2004-02-19 04:41 AM
2004-02-19 11:27 AM
2004-02-20 06:07 PM
2004-02-21 07:06 AM
Adalbert wrote:Besides the units (you should set the same units in Translator before opening) also check where the origin is; if it is light years away, that also might be a problem.
All what I have to say is that I newer had a problem with a DWG in 7 and I have plenty of crashes trying to open them in 8.1 Most of these drawings are created in ACAD2000 and yes the unit measure is all over the place but this should not be a problem as was not in 7.
At the moment I open all in 7 because that works.
