2004-02-16 03:21 AM
2004-02-16 05:45 AM
2004-02-16 11:41 PM
tprokop wrote:Check where and when? –there are any dwg conversion dialogs, the process comes straight through to a blanc screen. I tried to first "preset" these with an openable dwg, no luck.
make sure to check wether the drawing are done in a model space or paper space and set the Archicad settings to match when opening.
2004-02-17 05:08 AM
2004-02-17 06:46 AM
tprokop wrote:Sorry to say but this trick didn’t help. It didn't ask anything. I tried with AC 7, 8.1 both open and merge and PM. There must be something rotten in the sending ACAD LT. Strange that other autocadists in the project have not complained.
Select to open the DWG and let it open to the blank screen. Select open file and open the drawing again (this time Archicad should ask for a translator.
2004-02-17 01:12 PM
2004-02-19 04:50 AM
2004-02-19 11:44 PM
kari wrote:PLT for which plotter? There might be control codes; see the discussion at
One question to AutoCAD experts. When I opened this PLT, Plotmaker gave an error message “unimplemented command was given” (or something like that) “EC”, “IR”, “UL”, “MC”, “AC”.
2004-02-23 01:05 AM
Djordje wrote:PLT was saved with HP DJ 500 24 –don’t know what the last figure means, but anyway I have no plotter and not to mention error codes for any of them.kari wrote:PLT for which plotter? There might be control codes; see the discussion at
One question to AutoCAD experts. When I opened this PLT, Plotmaker gave an error message “unimplemented command was given” (or something like that) “EC”, “IR”, “UL”, “MC”, “AC”.http://www.graphisoft.com/community/archicad-talk/viewtopic.php?t=1519
HTH,
2004-03-08 07:27 AM
