Collaborate forum
ARCHICAD Connection Add-In for Revit 2018
The ARCHICAD Connection Add-In for Revit 2018 was released today. You can download it from the here:
http://www.graphisoft.com/downloads/interoperability.html
This is the INT version, other versions are on their way.
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
22 REPLIES 22
Steve Jepson
AttilaKadnar wrote:
I am looking for a way to import RVT to Archicad 20. Please help. Tanks, Cheers
Vectorworks can import Revit files (not an add-on or plug-in) so my guess is that ArchiCAD will have it soon enough too. ?
ArchiCAD 25 4013 USA - Windows 10 Pro 64x - Dell 7720 64 GB 2400MHz ECC - Xeon E3 1535M v6 4.20GHz - (2) 1TB M.2 PCIe Class 50 SSD's - 17.3" UHD IPS (3840x2160) - Nvidia Quadro P5000 16GB GDDR5 - Maxwell Studio/Render 5.2.1.49- Multilight 2 - Adobe Acrobat Pro
AttilaKadnar wrote:
Archicad 20 is a little old now so you will probably find that there won't be anything developed for it for a direct exchange like the BIM6x exchange mentioned earlier (for 21 & 22).
If you absolutely need it is 20 then you will have save it as another format in Revit that Archicad can open (IFC maybe but this will just be the model and I don't believe the annotation).
Or open it in 21 or 22 with the BIM6x exchange and than save back to 20.
Versions 6.5 to 25
Link
Sorry, you'll need to upgrade to use the BIM6x add-on: https://bim6x.com/solutions#
Link.
Get your ARCHICAD 25 Template HERE!
