On the machine where the BIM Server is running, the BIM Server Manager is accessible from the BIM Server Control Center.
(You need to install the separate BIM Server Manager application only on other machines you wish to be able to administer the BIM Server from.)
Here you do not need to be a Server Administrator for the BIM Server to be able to work in the BIM Server Manager (no User Name and password needed). It is understood that if you have your access to the computer (by logging into Windows or Mac) you will also have authorization to modify the settings of the BIM Server Manager.
