Teamwork & BIMcloud
Access rights to story and layout settings on AC 16 teamwork
We are running an Archicad 16 teamwork project with a colleague and neither of us can reserve and edit the story settings or reserve and edit the layouts. Everything else can be reserved and edited...
5 REPLIES 5
Stress Co_
This is a guess:
Open the "BIM Server Manager" and check your "User Roles & Rights" for the project.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Mac OS 10.15.7 (Catalina) //// Mac OS 14.2.1 (Sonoma)
Same problem here. I cannot find the Bim Server Manager menu anywhere, could somebody help me?
BIM Server Manager is a separate program that needs to be installed on someone's computer in the office (usually CAD manager). This is included with the ArchiCAD software CD.
This is where user rights can be changed. So check with other members of your teamwork project to see if someone has already installed this one their machine. I think it is a requirement someone has this installed for the file be shared as a teamwork file.
On the machine where the BIM Server is running, the BIM Server Manager is accessible from the BIM Server Control Center.
(You need to install the separate BIM Server Manager application only on other machines you wish to be able to administer the BIM Server from.)
Here you do not need to be a Server Administrator for the BIM Server to be able to work in the BIM Server Manager (no User Name and password needed). It is understood that if you have your access to the computer (by logging into Windows or Mac) you will also have authorization to modify the settings of the BIM Server Manager.
Thank you for your answers. I have already solved it.
