Add null value to Interactive Schedules
on the screenshots russian ARCHICAD but I hope it's not a problem. I will translate screenshots
Here my Interactive Schedule (IS) settings https://prnt.sc/oz3kmq
As you can see on the criteria:
element type: Window
Element ID: ОК-18
Floor: 2 (5,650)
On the fields you can see:
Element ID
Floor
Count
So I want to count the number of windows with ID ОК-18 on the 2nd floor (5,650)
Here the result https://prnt.sc/oz3le3
As you can see result is empty because I have no windows with ID ОК-18 on the 2nd floor in my project.
But I need to have digit zero or simple dash as a result. Not empty table. Is it possible? Thanks.
4 REPLIES 4
Are you using Archicad 22 ?
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
Yes,
v 22 5021 RUS FULL
Sorry
NO!
I use v 21...
But I can migrate to v22. It is not desirable. But if it helps I will migrate to v22
I thought your request could be solved with an expression into Archicad 22
Like this :
Christophe - FRANCE
