2022-04-11 04:18 PM
Hi everyone
I'm looking for an aluminium handle bar (the bars that have the height of the door and that you pull or push).
I have tried to create a custom one with a cylinder but unfortunately it does adapt to different heights for different doors.
Thanks for help.
Best regards.
Solved! Go to Solution.
2022-04-12 04:28 AM
Yet custom handles on cabinets have size parameters that you can change... GS inconsistencies as usual... It is not even that the parameter does not exist, it is just that it is only available in the handle macro itself and is set to fixed values depending on the handle chosen...
Win10 | R5 2600 | 16GB | GTX1660 |
2022-04-11 06:38 PM
Door handles appear always with their fixed size. You can only place them on required location over door leaf surface hence design different handles for different sizes.
2022-04-12 04:28 AM
2022-04-12 07:52 AM
Than you both for your replies
I will add the option to the wishlist....
Best regards.
2022-04-12 08:01 AM
Do you not have 'Panic Bar' options for the handle types?
Is that what you are after?
Or is this yet anther difference between INT and USA libraries?
Barry
2022-04-12 08:47 AM - edited 2022-04-12 08:50 AM
Think they are wanting a vertical full height handle.
"...bars that have the height of the door..."
2022-04-12 09:01 AM
I thought it might have been a typo - height/width.
But yes, if it is a vertical bar and Bidaya wants different sizes, then they will have to create a custom objects for each size.
The height position can be adjusted in the door settings, but not the length of a vertical handle.
2022-04-12 10:20 AM
This is what I am looking for.
