2007-01-18 12:16 PM
2007-01-18 02:09 PM
2007-01-18 09:43 PM
2007-01-19 06:15 AM
2007-01-19 03:35 PM
2007-01-19 05:54 PM
2007-01-20 04:25 AM
2007-01-20 05:16 PM
2007-01-20 05:34 PM
Adalbert wrote:For a well organized template, I've never found this to be a serious problem. For the few times that the layer combinations to need modifying, I can always open the team leader PLC that resides on the server and make the necessary adjustments. (We keep the team leader always signed in without any portion of the project and a PLC saved on the server so that team members can open this file to make adjustments without having to sign out of their workspace.)
The big problem in Teamwork is that only by signing in with full acess the layers and layers combination could be modified. This is unacceptable.
2007-01-20 07:23 PM
Adalbert wrote:It's also inaccurate. Team Leader can edit layer combinations without "full access"
For small offices it would be better to alow multiple people say max 3 manipulate a file on a server. This is much more productive than the present one.
2007-01-21 10:35 AM
2007-01-21 12:47 PM
Adalbert wrote:Yes, you can add layers in both AC9 and 10. If you just want to add a layer to a project, you can even do it as a Team Member. Only revising layer combinations requires Team Leader. That was ture back in AC8.1 as well.
Maybe in 10 in 9 one does not add layers without full access.
2007-01-21 03:37 PM
2007-01-21 04:48 PM
2007-01-22 04:07 AM
I guess I'm not exactly sure how this works, but it sounds great...do you just save the plc. on the network,and that subsequently changes the pln. on the network? Does that update it or does that replace it? Thanks
2007-01-22 05:36 AM
Millard wrote:Wow, you're responding early...thanks. Anywway...this sounds great, but are you able to update more than just layer combinations in the PLC?
Right,
I save the TeamLeader PLC to a folder in the project file on the server. The team leader stays signed into the project without any stories, layers, details, sections or layouts. This way if anyone on the project team needs to tweak a layer combination they can open the Team Leader PLC and update the combination and send and receive the changes. It would be best if this was managed by one person, but too many times a change has been needed while this person was out.
2007-01-22 06:03 AM
2007-01-22 06:37 AM
2007-01-22 06:55 AM
Millard wrote:I've used a similar approach myself and found that can work pretty well, especially if there is no clear leader among the group.
2007-01-22 07:00 AM
Why not use Hotlinks? Everyone can do their part on the project and everything can be shown on a master file. At the end you just break the hotlinks and you have the whole project on one file...Tom, can you explain please whats wrong with the above ?
