ArchiCAD 13 to 11
Hello !
Can someone tell me, how can I save ArchiCAD 13 to 11...
Thank you !
Matjaž
Erika Epstein
You can do a save as and for file type choose Archicad 11.
But, you will have to reset all your library parts back to AC 11 as it will not be able to read newer library parts.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
All I can choose in SAVE AS is ArchiCAD 12, not 11... and it doesnt opens it... is there like a add-on file (like for save as to Artlantis 3? )?
Any idea ?
David Maudlin
Matjaž:
Each version of ArchiCAD only saves back one version, so to go from ArchiCAD 13 to 11, you need to Save As... in 13 to 12, then open that file in ArchiCAD 12 and Save As... to 11. If you don't have 12, then talk to your local reseller (the dongles work with previous versions). Erika's advice on library parts stands: ArchiCAD 11 will not be able to read 13 library parts, and there is no easy way to change a library part to an earlier version.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
