Collaborate forum
ArchiStair for Ac9?
Anyone know if there will be an Archistair for Ac9? If so, is there an ETA?
18 REPLIES 18
Fabrizio Diodati
As I already wrote, It will be available during this week.
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy |
phone: +39 041 8943500 | Skype: fabrizio.diodati |
email: fdiodati@graphisoft.com
Thanks Fabrizio.
BTW did you see the email I sent to Cigraph about being unable to 'register' ArchiStair? I logged on to the web site via the 'connect' from ArchiStair, but the serial number didn't work, so I sent the serial and the dongle number by email to Cigraph in the hope that you could help.
Do you think that I will have the same problem with ArchiStair for v9?
Fabrizio Diodati
Please MikeS,
could you forward also me your e-mail regarding your serialization trouble?
Thanks
Fabrizio
Fabrizio Diodati
Just a question fabritzio.
is there any plan for a new api?
If it can be said (and there is a plan) what is it about?
thx
Fabrizio Diodati
Hi oreopoulus,
what do you mean?
Do you mean a plan for a new version of ArchiStair?
Do you mean a plan for new Cigraph add-ons?
We are not working on a new version of ArchiStair (just releasing new maintenance updates and waiting for the user feedback on which we will base the next version).
About the next add-ons:
1. Before the endof this year we will release ArchiRuler 2.0. A lot of new functions, improving the old ones.
2. We are working on a new add-on (ArchiPanel) for ceiling and floating floor. Quite interesting I think (and I hope!).
3. In the same time, the new version of ArchiWall is quite near to be finished. You will be able to model free form walls (like before) but the result can be graphically edit by dragging the hotspots. A lot of new function like the features to model the front view of the walls and like the issue to create free form shaped hole/niche without GDL scripting.
We have also some plan about curtain walls but I don't know if a "specific" add-on for this purpose could be interesting (who knows?) maybe we could delay just a bit ArchiWall and add this code into it...
If I misunderstood your question please don't hesitate to contact me.
Friendly
Fabrizio
Fabrizio Diodati
I was talking about new cigraph add ons and your answer was very informative.
THx a lot.
The archiwall with hotspot editing would be greate.
and one question. Do you think there is a need for smthg like archirailing?
Fabrizio Diodati
Archirailing?
If yes it should be integrated into ArchiStair... at least I think.
Please, if you have time, send me your ideas/suggestions it should be very usefull.
Fabrizio Diodati
Let me state it in generic steps.
and then refine
1) Create the rail scheme
2) Define a 3d poliline as a path
3) Create the railing.
Now lets refine step 1.
There are 3 basic parameters needed
1) the small wall under the railing (if present)
of course one can do that on its own but its easier to have the railing in one part.
2) Railing design.
That is a more comlex part because we have to seperate cases.
a) Straight parts (not arcs)
b) Poliline contains arcs.
Now here is the hard stuff.
We usually have vertical and horizontal LINEAR elements and also some 2D elements.
In straignt parts there is not problem with either parts.
With curved parts we have to define that the horizontal linear element has to be rotated by its axes.(this needs some picture to be clariffies.)
Generally the linear parts can be extruded or revolved through a path. and that path has to be integrated somehow through the whole proccess.
The last parameter is the number of repetitions but this is really very simple stuff that only demand the pattern to be resised accordingly.
This are some first thought.
I can make them much more clear working them in paper and in my native langruage and then posting them here.
Hope that helps.
Fabrizio Diodati
Don't worry for your English... it cannot be worst than mine!
BTW, just a silly question: don't you think you already have a lot of this using ArchiStair?
One of the ArchiStair issue is to hide anything you want (also the stair itself!) so you can already get something of very similar to which you are looking for...
Fabrizio Diodati
Hmmm
I have not search the railiing customization because i thought it was the usual predifined railing...
I will do so.
I will spend some time on archistair and come back with my homework done
Fabrizio,
Regarding other add-ons....
A curtain walling add-on would be good, possibly with a parametric window generator as well. ArchiDesigner was an add-on that generated parametric windows for up to version 7, as you are probably well aware. The ArchiCAD library curtain wall objects are good but not quite smart enough, for example you cannot create a faceted curved curtain wall, although of course curved curtain walling is ususaly faceted. AutoCAD ADT has a specific curtain wall tool I believe.
Regarding ArchiStair, I think its great, am enjoying using the v9 copy at last. The editable hotspots are really useful to sort out irregular shapes for top and bottom treads. As I mentioned before handrail heights on landings in the UK have to be different from on the flights of stairs, so ideally there would be a hotspot in 3D on landing handrails, allowing you to adjust the heights.
Also an ArchiStair wish list item....
As it is possible to build your own toolbars and access all the commands in ArchiCAD 9 (more or less), you can add the "Show ArchiStair pallet" command to a toolbar, but there is no icon for it. Therefore you get the whole lot in words which is too long. Can the ArchiStair api provide icons for the menus so that you can put an Architsair icon on your toolbar (assuming this is possible in ArchiCAD). The same would go for all the other Cigraph add-ons.
Fabrizio Diodati
Ok...
added to the Archi-Cigraph wish list!!!
Fabrizio Diodati
Daniel Lindahl
Andy wrote:
....The ArchiCAD library curtain wall objects are good but not quite smart enough, for example you cannot create a faceted curved curtain wall, although of course curved curtain walling is ususaly faceted. AutoCAD ADT has a specific curtain wall tool I believe.
Andy
Have you looked into my Curtain walls objects available at Objects Online? There is a straight and a curved (faceted) object. They might fit the bill. At present they are Objects, and contain glazing and mullions/transoms only, with an even grid.
Take a look and see what you think.
cheers
Daniel
Daniel Lindahl Architecture
AC20 AUS+BIMx | Dell Inspiron 17 SE IntelCore i7 64bit 3630QM 2.40GHz 8GB ram | Windows 10 Pro
Gorazd
Dear Fabrizio
When I try to launch ArchiStair in AC9 I got the message: Invalid unlock code or unlock code file is corrupted!
I tried to reinstall ArchiStair, get the unlock code again from cigraph web site, but nothing helps. Where is this file located? We have NET 3 ArchiCAD.
regards
Gorazd Rajh
AC 25, i9, 32 GB RAM, nvidia RTX 2070, Win 10
Fabrizio Diodati
This means you are trying to use another dongle (different from that one used to got the unlock code)!
Did you change your dongle (maybe for update reason)?
Fabrizio Diodati
Gorazd
I really don't know what happened (it is a customers site). They have only one keyplug NET 3, and they just bought the ArchiCAD 9. They tried to register ArchiStair and then phoned me, that it doesn't work. When I went over there, there was nothing I could do. Is there a way to resolve that?
Gorazd Rajh
Dear Fabrizio
Could you please advise on our course of action in the following situation: The office I work for purchased a copy of Architerra, and ordered six copies of Archistair.
These were all unlocked using the parallel port dongles on machines at the time.
When we ugraded to ArchiCAD 9.0 we were told that USB dongles were required, consequently with these new dongles came new serial numbers and our Cigraph plugins no longer function!!
Is there someone I can email the details to, can our plugin licenses be re-serialized to our new dongles??
I realise this is sensible security for your software, but I am hoping there is a way out in our situation.
Many thanks,
Simon McLean
Fabrizio Diodati
Dear Simon,
of course this isn't your fault but any of our Distributor should well know the procedure to solve this issue!
I simply need a sort of certification from your Distributor (or from who sold you the software, usually OOL in the USA market) saying you changed your ArchiCAD dongle and I will immediately reset all your Registration ID that means you will be able to serialize all your plug-ins, once again, using the new dongle... of course free of charge!
The serialization process is, for sure, a security for our software but the users don't have to pay for it!
Friendly
Fabrizio
Fabrizio Diodati
