ArchiTerra to Mesh
Hi!
We should draw/modelling a building where the terrain have highest priority and it is a halfcomplex terrain.
Then I thought about modelling the terrain i ArchiTerra.
How does it work if anyone else without ArchiTerra opening our modell?
Could I after I build the terrain convert my ArchiTerra mesh to an standard ArchiCad mesh?
2 REPLIES 2
Thomas Holm
TurboGlider wrote:
Hi!
I wouldn't recommend that. I tried to do the same a year ago. I ended up ditching Architerra altogether.
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Probably there is a basic misunderstanding.
ArchiTerra doesn't create "special" meshe elements: it uses the ArchiCAD meshes so there is no need to convert these elements into an ArchiCAD mesh because they arleady are ArchiCAD mesh.
Friendly
Fabrizio
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
Learn and get certified!
