ArchiTiles
I create a new tile.
I create elevation from the room, i apply the new tile.
On the statge of rotating my elevations back to the room, it give me the message telling that it can not find the picture related to the tile that i create.
could anybody help?
Thank you
6 REPLIES 6
Ben Odonnell
Hi there,
If it's only complaining about the image, it means that you don't have it loaded in your active library. Load in the offending image, then the error message should disappear.
HTH.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
The Problem that it's loaded and i tried to put it on the same folder as well; but didn't work.
i open the tile as a GDL, and i check the 3d script it has a problem.
I'm not so good with GDL, so i don't know what to do!
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Send me both the tile and the image and I will tell you what's not working...
Friendly
Fabrizio
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
I have sent it by email to you.
Thank you for your cooperation.
PS:my email is: fossil@link.net
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
I got your tile and anything is clear now!
You save the tile enabling the "randomize texture" option:
this means ArchiTiles assumes you have into you library several images with very similar names.
As you can read in the user manual:
"You must have multiple images (textures) saved in an ArchiCAD active
library. They also must be saved with the same name except the last
digit which must have a different number (the first image name without
a number, then the second image with the same name and the number
2, the third image with the same name and the number 3, etc.). Here is
an example of how the different textures must be named in the
ArchiCAD library:
1st image: pink_marble
2nd image: pink_marble2
3rd image: pink_marble3
4th image: pink_marble4
5th image: pink_marble5"
In your case, you create a tile with the randomize texture option but you only load 1 image!!!
Friendly
Fabrizio
Fabrizio Diodati
It's working, Thank you for your cooperation.
