Archiad ODBC and Oracle
Good morning:
Someone made ​​a connection to odbc for archicad 16?
I'm working on a machine with windows 8 and I'm trying to make a 64-bit dns to connect to odbc archicad 16 but in the second step, in which you specify the data type bigint crashes and closes automatically.
Then made ​​a 32-bit dns to connect to odbc and it worked. Now, try to make a connection to Oracle heterogeneous services and make a link to odbc archicad, but after setting the tnsnames.ora, listener.ora and the initialization file, it throws the error ora-28500, which says that is not the name of the data source and no default driver specified.
Please someone help with this.
Thank you.
David.
0 REPLIES 0
