Collaborate forum
Archicad 12 and Windows 10?
davidlan
Is there any reason why i shouldn't upgrade my OS from Win XP32 to windows 10?
Are there any compatibility issues?
Thanks
3 REPLIES 3
Archicad 12 was released 13 years ago.
You should not expect it to be fully compatible with Windows 10.
You can try but I don't know if it is possible to do real production work with it. You need to test it on a Win10 system, and if it works, you can upgrade your own system.
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
You will save more time upgrading your Archicad then dealing with legacy software for a legacy system.
vistasp
Since the system requirements for AC10 are so minimal (in comparison to the machines available today), you can try running it inside a virtual machine with XP.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-26 INT | Win10 | Ryzen 5700 | 32 GB | RTX 3050 |
