Collaborate forum
Archicad 18 Bim Server Backup
Chadi SAROUFIM
We had the option in 17 to backup the BIM server projects? where can we do that in 18? Thank you.
Chadi Saroufim, Assoc. AIA
M. Arch & M. Urban Design, Partner
Idepconsult – Mounir Saroufim and Partners
ArchiCAD 23 INT
Windows 11
4 REPLIES 4
Matthew Johnson
I'm looking for a way to have better control over the PLN backups that BIM Server creates. The PLN files are created by the client machines and saved back to a backup folder on the BIM server with a file name that records only the time and date.
What I'd like to be able to do is direct these PLN backups to another network location (NAS, Server drive with offsite backup etc.) and have them use the project name in the file naming convention so that I can search the backup files.
Does anyone have any idea if this is possible?
Matthew Johnson - P O W E . Architects
AC25, Windows 11 64bit
Dell Precision 5520 i7 w/ Nvidia Quadro M1200 4K dual
i9-12900K w/ Nvidia RTX 3080 4K
I'd rather be sailing.
In the BIM Server Manager, go to the Projects page.
Then on the left pane, click the Project name. The right pane shows the Project settings. (You might have to make your browser full screen to see everything). At the top in the right pane you can see the large buttons called Settings, Backups and Activities. Click the Backups button and there you can set the backup schedule by clicking the Edit button.
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
This is not possible unfortunately. The only thing you can do is when you create a manual backup you can specify a name for it.
Is it possible to access automatic backups if the project itself has been deleted from the server and not exported?
