Archicad 20: Export to DWG
I am trying to share a Plot Plan on Archicad 20 with an autocad user using the DWG drawing. I tried to rename in file "save as" and it will not rename. Have not had this problem in the past. Any input to start?
1 REPLY 1
Eduardo Rolon
Check your DWG Translator settings under File->Interoperability to see if the Autocad version you are saving to is correct. Recommendation is to set it to an older version of Autocad (like 2004) to avoid compatibility errors
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Learn and get certified!
