Collaborate forum
Archicad 20 to C4D
emerich
Hi
When re-exporting an Archicad model to C4D (with Vray) for rendering, I've discovered that I cannot reference the previous file's textures, cameras, rendering settings etc. I had used the 'din3d' plugin on previous versions of Archicad (which was incredible btw) but this is no longer available for new versions. The current export plugin does not even 'tag' the Archicad model within C4D - further evidence that referencing was not considered in this plugin!?!?
What plugins do other renderers use for exporting to C4D - so one has the option of updating the Archicad model in the future?
Thanks for any insight
e
standard-practice.ca
AC24 USA Full
MacBook Pro
2.9 GHz Intel Core i9
Since AC 4.55
14 REPLIES 14
rodut1112
The current cinema4d add-on shouldn`t even be called an add-on at all. Its useless. I can`t handle large scenes. You all should take a look at now defunct Din3D plugin, and learn from it, or acquire it, because its development stopped. The speed it can export large scenes(under 2 minutes for large scenes), the optimization of those scenes(10% of the number of objects your add-on exports). No one needs a curtain wall to be splitted in 1000 objects for the glass part and another 2000 objects for the structure. The UPDATE option its the most important thing you have to take notes. Please HURRY UP because the current workflow to export to the only professional 3d aplication part of the nemetschek group is S**T.
SeARCH architects
www.search.nl
ArchiCAD 20-22 NED
MacOS Mojave | Windows 10
emerich
Still true to this day and could not have said it better myself.
AC24 USA Full
MacBook Pro
Since AC 4.55
prot158
The last plugin I have works on Archicad 20 et C4D R18. I you have purchased the plugin before, just send him an email to request to update your C4D serial.
Here are the links I got from Din3D newsletter
Plugins for Archicad -> 20
Archicad exporter (win)
Archicad exporter (mac)
C4D:
R12
R13
R14
R15
R16
R17
R18
AC24 - MacPro 5.1 OSX Mojave
rodut1112
Lets hope that he will update for archicad 21 also. But still graphisoft has to improve this workflow.
SeARCH architects
www.search.nl
ArchiCAD 20-22 NED
Eduardo Rolon
+1000
eduardo rolón AIA NCARB
Another of the forum moderators.
Macbook Pro 2.4 i9 32GB ram
OS X 10.XX latest
AC25 US/INT -> AC08
prot158
What is worse, it's that the Din3d plugin is just the same (improved) as it used to be before. It was a paying add-on from graphisoft. Now it's free and useless
rodut1112
2017.......Archicad 21. Still no improvement. Good job GS. Keep it up!
SeARCH architects
www.search.nl
ArchiCAD 20-22 NED
DGSketcher
I have only exported to C4D once to an external consultant. This was done by setting up the 3D view, going to the Photo Rendering Settings window, Select Engine: Cinerender by Maxon, Select the down arrow next to the camera at the bottom of the window and choose Export to Cinema 4D. This creates a 3D file and sub folder of textures. I mailed these to the consultant with a PDF of my rendering and he said everything opened as expected.
Apple iMac macOS Big Sur / AC24UKI (most recent builds)
rodut1112
Its basically the same method as saving as .C4d. The difference is that the scene combine option pop-up and it saves more elements for lights/sun setup. The issue still remains, that you can`t update the file if you run the scene combine command. At least I rediscovered the archicad scene combine in C4d. Thanks.
SeARCH architects
www.search.nl
ArchiCAD 20-22 NED
prot158
Good news. The exporter for archicad 21 is out.
win
mac
rodut1112
win
mac
Thank you!!
SeARCH architects
www.search.nl
ArchiCAD 20-22 NED
ciciolo
You're talking about maxonform, I guess...
prot158
Sorry, late answer.
Nope. MaxonForm is the origin of the actual exchange plugin.
Before there was that:
dinnye
Hi
Din3D is available again. Check it...
http://din3d.net
ArchiCAD user since 1994y
>ArchiCAD
>Cinema 4D
http://din3d.net/
