Teamwork & BIMcloud
Archicad 21 Teamwork Error : Generate Lockable Objects Changes Failed
The project I'm currently working on in Archicad 21, Teamwork just got the error below:
Error Occurred During Last Teamwork Operation: Generate Lockable Objects Changes Failed
I've prepared the support package and will send it out. Until I get a reply on that, I want to start cleaning the model. My guess is that it's the embedded library that is creating the headache.
Could you help me with a quick fix
Thanks,
Ana
1 REPLY 1
Hi never came across this error.
However, have you checked locks of layer and elements? Espatily those under Edit/Lock/. Those two are not the same. Maybe some elements were changed in a file and then locked or where change by other user and you have them locked? Not sure just a guess to test.
