2019-02-04 03:08 PM
2019-04-10 04:12 PM
2019-06-24 05:56 PM
2019-08-18 06:29 AM
davor_r wrote:Dear davor, Since you use this translator everyday, can you help out with the dimension error of the exported dwg file? Thanks!
I use a pln to dwg translation every day. There is no problem just need to understand things. as Mikas said, saving from the model is the direct saving of the working file. While saving from the layout (which I presume is the case here) is another matter.
Namely, when you save from the layout, with the frames and margins set, the layout view also opens in the autocad. When you click the model view (lover left part of the AutoCAD interface screen), there is a "stiffed" drawing that looks like jpg or pdf. This is the way to work with the so-called x-ref files (referenced files). They serve only as a basis, through which it is drawn into the autocad. When you send new x-ref files to colleagues, they only replace them. As an old system of manual drawing and stacking of paus paper one over the other.
You can set the option to send x-ref files or editable drawings in the translator.
2019-09-24 11:27 AM
2020-01-30 12:52 PM
RE: ARCHICAD 22 DWG TRANSLATORS#296216Has this been addressed yet? This is still a very contemporary problem for our office. and for the record, it appears to affect any file openned in current versions of autocad, regardless of the file format version we save it down to.
By dkovacsGRAPHISOFT - Tue Apr 09, 2019 1:23 pm
Hello Everyone,
I think the original issue of the subcontractors is probably how mikas explained. I just wanted to comment on the issue Laszlo Nagy pitched:
LaszloNagy wrote:I encountered a strange thing while checking out this issue.This is because of an error in the engine we use for the export of AutoCAD 2018 DWG files. We have identified the issue and planning to solve it in ARCHICAD 23 (fix #258978).
I have saved 2 DWG from ARCHICAD.
The first I set to be saved in AutoCAD 2004 format. It opened without issue.
The second I set to be saved in AutoCAD 2018 format. When I opened it in AutoCAD 2019 it gave the following warning, stating that it was created in a Student Version so there will be a plot stamp in it. I will report this issue to GRAPHISOFT.
Since this issue only affects AutoCAD 2018 DWG export, if you export to any other earlier version (e.g. 2017), it will work fine.
Regards,
Daniel Alexander Kovacs
Technical Support Engineer
GRAPHISOFT
2020-01-30 01:20 PM
