Archicad Revit connection addin not working
Roger C
Installed Archicad Revit connection addin in Revit 2015. I can't get it running. When I open Revit there's no button on Revit's addin tab. It has happened to a couple of friends too. Could it be a windows 10 issue?
i7 3770K / MSI GS73VR 7RF i7 7700HQ
16 gb
GTX 3060 / GTX 1060
Windows 10
ArchiCAD 25 SPA
2 REPLIES 2
Katalin Borszeki
Hi Roger C. This used to be an issue with older builds of the Revit add-in. Since the 5005 build, we have not experienced it. Please try downloading the latest build:
http://www.graphisoft.com/downloads/interoperability.html
best, k
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
Roger C
Forgot to mention I've already got the latest version of the addin. My OS is Windows 10 64 pro, if it has to be mentioned.
It has to be said that a couple of friends of mine had the same problem. We needed to exchange ifc models between archicad and revit for a competition, and neither of them could properly run the addin. Our version of Revit is spanish located, so could it be an issue there?
16 gb
GTX 3060 / GTX 1060
Windows 10
ArchiCAD 25 SPA
Learn and get certified!
