2022-02-17 12:50 PM - edited 2022-02-17 12:51 PM
Is there some way to prevent this besides exploding the drawings first? Perhaps I have some setting in the Translator configured wrong ? For example, I joists objects that have been stretched to 20' will all be at the default length in the .dwg. Shower Tray make 3'x5' will revert to 3'x3' in .dwg....
I am using AutoCAD 2022 and Archicad 25 objects for this. anyone else have this issue?
ArchiCAD 25 5010 USA - Windows 10 Pro 64x - Dell 7720 64 GB 2400MHz ECC - Xeon E3 1535M v6 4.20GHz - (2) 1TB M.2 PCIe Class 50 SSD's - 17.3" UHD IPS (3840x2160) - Nvidia Quadro P5000 16GB GDDR5 - Maxwell Studio/Render 5.2.1.49- Multilight 2 - Adobe Acrobat Pro
Solved! Go to Solution.
2022-02-17 03:29 PM
If it's a library object which is giving you trouble, take a look here:
Solved: Kitchen Layout Object - Goes Bonkers When Saving D... - Graphisoft Community
Archicad 4.55 - 25 | HP Z840 | 2× E5-2643 v4 | 64 GB RAM | Nvidia Quadro M5000 @ Windows 10 Pro x64
2022-02-17 03:29 PM
