Collaborate forum
Archicad to 3ds. Textures problem.
Hi.
I have problem with exporting archicad model to 3ds max with properly mapped textures. I do everything as advised (export with "surfaces" and "archicad textures information" options ticked).
All textures are exported as a .bmp format and are not properly scaled in 3ds max material editor no not to mention model space. When I manually convert image from .bmp to .jpg it works perfectly, but I have hundreds of textures so cannot really do everything manually.
Is there anyway to force archicad to export textures with 3ds file as .jpg not .bmp?
1 REPLY 1
sinceV6
Hi.
Forget the texture information. If you are exporting to 3ds max, I suppose it's to render there, right? Just use the geometry information, and set up your materials directly in max. Will work better.
Best regards.
