Archisketchy type renders
John Weaver
I miss Archisketchy. Is there any add-on out there that gives the easy and simplicity of creating sketch renders like Archisketchy or Sketchup. While I have seen some people get a good sketch rendering form AC, it seems to take so much more tweeking, where as Sketchup and Archisketchy seem to give good sketch renderings of perspectives and floor plans straight out of the box. Any good advice or good setting for the Archicad photo rendering settings?
7 REPLIES 7
Erwin Edel
Can you show some example of what you are trying to achieve?
I use the sketch render a lot combined with cinerender and some photoshop filters for anything ranging from near photorealism with just a touch of linework to define edges, to hand-drawn watercolor style stuff.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Stress Co_
For me... the benefit of ArchiSketchy wasn't in it's use for 3D perspectives
(the sketch engine works fine) but in plan and elevation views.
I can get pretty close, by viewing the 3D model in Parallel
Projections> (Side View for elevations, Top view for floor plans),
and using the Sketch Render engine, but I lose any 2D notes (which have to be duplicated on the layout).
ArchiSketchy was much simpler.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Mac OS 10.15.7 (Catalina) //// Mac OS 14.2.1 (Sonoma)
Stress Co_
An ArchiSketchy Generated Elevation:
Erwin Edel
A trick I've used to quickly scale plan views / elevations / section that I've rendered to look like they are hand-drawn, is to make a 'frame' of simple morph lines with a nice round dimension. Select the frame in 3D (with the rest of the model there of course) and pick 'zoom to selection'. If you make a render after that, you can set it up to have the same aspect ratio as your 'frame' and even render it at about 300 dpi to be excactly on the scale you need it to be.
You won't get sketchy labels or dimensions, though.
On a similar note, to show door swing I've just drawn some morph swing lines for the floor plans.
Circles still look bad though, but can't win them all.
I like mixing different sketch styles together by either hiding layers and rendering with different thickness/pen style, or by turning every thickness to 0% and only rendering the shadows or vectorial hatch, allowing me to oversize the contours, but keep the hatching neat and using a heavy weight pencil style for shadows. Just put everything in photoshop and set layers to multiply.
And sketch renders generally take about 5 seconds to render, so the process doesn't take that much time. Especially if you save your presets as scenes.
www.leloup.nl
Windows 10 Pro
rm
Hi Marc,
How are you getting ArchiSketchy to work in AC 21? ArchiSketchy is not listed as available on Cigraphs website in the latest ArchiSuite.
Thank you,
Robert Mariani
Robert Mariani
MARIANI design studio, PLLC
www.robertmariani.com
Mac OSX 13.1
AC 24 / 25 / 26
rm
It kind of seems like a natural feature to add into ArchiCAD itself. The software has gotten much better over its lifetime, but some things just never seem to change. Architects dont always want to present hardline drawings to clients, especially during Schematic Design phase or for design presentation work.
Come on Graphisoft, give us this line treatments that emulate hand drawing much like Skecthup and ArchiSketchy.
Robert Mariani
Mac OSX 13.1
AC 24 / 25 / 26
Stress Co_
I haven't used it since about AC10
The last time I inquired to Cigraph (2016), it was still included in the ArchiSuite.
I couldn't justify the cost of admission (today's price is 795.00 euros, about $984 USD).
I only wanted that one plug-in.
