Area of walls minus openings
Is there a way of showing the area of walls less the openings?
I have tried all the options in the wall schedule & searched the forum.
This would be a great time saver for me when doing thermal calculations.
10 REPLIES 10
laszlonagy wrote:
However, I just found that
the "Net Surface Area on the Inside Face" gives an incorrect result for me when the Reference Line is on the Outside Face of the Wall and
the "Net Surface Area on the Outside Face" gives an incorrect result when the Reference Line is on the Inside Face of the Wall.
It seems to me that ArchiCAD adds the surface are of the two side edge surfaces to it unnecessarily (AC17 b6004 INT). I will forward this issue to Graphisoft.
I got word from Graphisoft that this was fixed in AC18.
