Arrays in PARAM-O
Hello guys, im having a little fun with the new PARAM-O, and it looks awesome! But I need now to make an array with variable amount of itens along the total dimension of my object (objects must have fixed space between them). Am I missing something or this is impossible in the current state of PARAM-O? If so, will it be ever added? This is a MUST for more complex parametric objects.
15 REPLIES 15
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Braza wrote:
Hi Laszlo,
I am also exploring Param-o. It is way more impressive than I thought.
I can see lots of potential. Specially for creating small GDL objects for CW and Railings.
But I think it lacks of some more practical tutorials or a more detailed documentation.
I would also like to know if there is any function that allows us to create custom user inputs on Floorplan or 3d. Like a path defined with a series of points. Or perhaps some source of Hotspots
Thanks in advance.
Thank you for the question! As far as I know, we will have Param-O training on the new GRAPHISOFT Learn website in the near future!
Regarding the wish to create custom user inputs on Floorplan or 3D, it would be great if we can implement it in the final version of Param-O! I entered it as a wish into our database (please refer to it as #12816)!
Thank you once again for your enthusiasm with Archicad 24. Have a great day!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Since we're suggesting new features, let me suggest some minor changes that would be great!
1 - Highlight the connection lines once we hover the mouse over them.
2 - Ability to disconnect node by just dragging the connection line out of the node.
3 - Change the output names of the nodes (currently it's all "Variable") to the type of it's output (like "Number", "Point", "Boolean", and so on)
These are minor change that would benefit a lot the workflow with Param-O
Thanks Minh! Much appreciated.
@juninholiveira
Yes! All good improvements.
I'd also add (In the middle future, as for now this is not essential) a graphical User Interface window. Where we could drag and drop parameters and it would automatically would create buttons, Text Blocks, checkboxes, sliders, etc that could be visible in the Object UI. It would be especially handy for Manufacturers to introduce commercial info for their products.
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi All,
Thank you for your suggestion!
I have entered them into our database as Wish #12824. PARAM-O is still in its early phases, but we hope that it will become something handy for your architectural works in the future!
Have a great weekend!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
is there already a Param-O training on het Graphisoft Learn website?
We are now 2 years later & I still can't find anything. It would be very helpful if there is any Parmo-O training or course...
Joke.
Joke Swinnen
BIM Modeller at Atrium Architecten
Archicad user since 2017 (v20 - v25) - CC iRT i7-12700 - 64 GB / Nvidia Geforce RTX 3080 - Windows 10 Pro 64
Hi @Joke Swinnen,
We did release a PARAM-O training on Graphisoft Learn that you can catch for free with our Community challenge coupon code. More details here.
Rubia Torres
Community Specialist | GRAPHISOFT SE
Need help refining your Archicad skills?
Check our Modeling knowledge base for the best workflow + tips&tricks!
