I guess it all depends on the type of work you are doing, whether you will be working with other companies (sharing files), or if authorities demand copies of the files that have to be in a certain format (do they do that in AUS?).
If you don't need to follow some kind of national standard (I find them so confusing) then don't.
Do what works best for you.
If it is just you (your company) using the plans, then make it a simple as possible for you to use and understand.
It does take time to develop a good template.
I would be very surprised if you can get it right at the first attempt.
Mine has been going for 20 years, and still gets tweaked from time to time.
Depending on the type of work you do, you may even find one template to fit all is not a good idea.
You may need different templates for different types of work.
Versions 6.5 to 25
