AutoCAD to ArchiCAD and back again....
When opening AutoCAD dwg (2002 format) some of the lines in colour 7 (white) appear blue and quite thick - with a thickness. Likewise, when the archicad file is exported as a dwg file and opened in autocad, the lines all have thicknesses. Can anyone please shed some light on this - and possible workarounds. Thanks
1 REPLY 1
Djordje
Ace
You are opening the DWG with pen number to pen number conversion rule. Pen No 7 in ArchiCAD is blue.
You also have the Tru Weight on in ArchiCAD. That is why your ine is thick.
Switch the True Weight off when saving DWG file.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
